Weird electrical fault.
/ Weird electrical fault. #1
Jamming
Gold Member
Northern Washington
John Deere 3033R
Was running my brand new JD 3005 today and all of a sudden it just shut off. Took the exhaust stack off opened hood. Humm don't see ant loose wires. Checked the safety switch, looks fine. Turn key. Nothing. :confused: try in and out of gear, still nothing. Pull fuse box cover and find a blown 5 amp fuel pump fuse. Look at fuel pump :confused: looks fine. Then I put a new fuse in after a 10 minute walk to the shop for tools and fuse. Starts right up and runs about 3 seconds, blown fuse again. Wtf ! So then I unplugged the fuel pump and put in a new fuse, I make it back to the shop and call my dealer. He ordered a new pump. Well I found the problem moments later.
The plug that goes into the pump was touching the little ear that was sticking out from the fuel hose clamp. In turn was blowing the fuse. Why post this ?
Well incase someone else might have a weird fuse failure like this they can make sure the plug is away from the hose clamp, the little crimp style.
/ Weird electrical fault. #2
Was the hose clamp attached to metal or on rubber touching metal and the pump?
EDIT- I bet it was touching the pump and electrical contact...
Looks like the hose is braided so I think it is well grounded. I was sitting in my house thinking the same think, but they look braided.
/ Weird electrical fault. #4
That would do it!!!! GM went that route inside teflon because of static spark fires when changing fuel filters on 1984 Celebrity 2.5 Liters.
I think tomorrow I will heat shrink the connector to prevent any chance of it shorting out again.
/ Weird electrical fault. #6
Good detective work! Fortunate that you weren't off in the woods a mile or so from the house...
Great info for other owner's as well! :thumbsup: Something for them to consider if their 3005 stops "pumping".
Spent a couple of weeks in Twisp about 30 years ago. Beautiful country! Could only afford to visit - never buy - that's always a problem when you're young...
AKfish
/ Weird electrical fault. #7
Good find Jamming.
North Washington ?
Where abouts ?
98446 is my zippy.
AKfish
Always find it amazing that where I live I can drive two hours time and go from a rain forest at 80" of precip to 6" of precip. Twisp is a great place to still buy in Washington. About $80-200 a square foot average.
/ Weird electrical fault. #9
Good find. A fuse blowing immediately indicates a direct short. A pump failing in such a way so as to put a direct short on the power input would be highly unlikely. I mean almost never. When there's a direct short, always suspect the integrity of the wiring and physical connections. Good job, and the price was right too!
I will also post some pics tomorrow of the exact location and plug.
/ Weird electrical fault. #11
I had an electrical fault on my Kubota. I was running it in a field and someone walked out to talk to me. I shut it down for safety and convenience (noise) and when they left it wouldn't start or even try to start. I was brush hogging and a stick managed to find its way to the connections on the starter and cause a problem. I found it and pulled the stick out and replugged the wire/connector back on.
Later I had intermittent problems with starting due to, I thought, an intermittent key switch. I bought a new switch but after taking the other one out of the mounting hole everything worked perfectly for nearly a year (with it dangling there) so I didn't install the new switch. Eventually the problem returned and I traced it to an in-line fuse. The switch was never the problem, just some coincidences made it look that way. Now I have a new spare key switch.
One of these days I'll stick the switch back into its mounting hole.
Pat
/ Weird electrical fault. #12
Jamming - is that near Squim (probably misspelled)?
/ Weird electrical fault. #13
Sequim
Went there to check it out for retirement. It was August. It was damp and drizzly the whole time and yet is heralded as "the banana belt", the rain shadow of the Ho peninsula.
B.S.
Pat
Sequim
B.S.
Pat
But no tornados. They get about 25" of precip in a year, but hoh rainforest gets 125" plus. Great place to visit but living there would require webbed feet. 1000 year old Douglas fir trees are amazing for sure. Seen plenty of the redwoods but the ancient Douglas firs are really amazing.
/ Weird electrical fault. #16
A number of Alaska retirees have "discovered" Squim! They couldn't be happier!! Ocean, trees, fishing and a very mild climate - drier than much of Alaska.
AKfish
RIDGID AIR COMPRESSOR (A63569)
RIDGID AIR...
60� Tine Rake (A64047)
60� Tine Rake...
2013 FORD F250 (A60460)
2013 FORD F250...
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
