New JD 1000 Series Cab
/ New JD 1000 Series Cab #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
Came across this picture from overseas:
Just wanted to share...
/ New JD 1000 Series Cab #2
That would make a fantastic lawnmower!
/ New JD 1000 Series Cab #3
...is that a 3 point hitch on the front? And yes, sign me up for mowing with that.
/ New JD 1000 Series Cab #4
Now that is one cool set up and it sure looks like a 3pt up front.
/ New JD 1000 Series Cab #5
Hiya,
Yes, the poeple on the other side of the Atlantic can get cabs on the smaller chassis. The 2000 series has had a cab option in the UK since 2006 however, unlike the 3 & 4x20 series, the 2000 series cabs have no AC but the doors can be taken off.
Tom
/ New JD 1000 Series Cab #6
That is really slick! I was thinking a nice zero turn would be nice the next time around but a cab with AC/Heat wouldn't be so bad:thumbsup:
/ New JD 1000 Series Cab #7
That would be great to combine a steam bath or dry sauna (depending on your climate conditions) with mowing your lawn in the summer. These cabs are great but only with a total hvac package. As an example I was pushing snow in my 4520 cab yesterday in the sunshine(36F) and had to turn on the ac in the afternoon.
/ New JD 1000 Series Cab #8
Looks like the same front frame that my 3720 has for the front mount blower, or other front attatchments.
/ New JD 1000 Series Cab #9
Let's have a pic of the other side, where the fuel filler is on the fender? How does this cab work around it?
A 3 point on the front??
/ New JD 1000 Series Cab #11
You'll probably never see it here. As mentioned europe gets cabs on alot of sub compacts, not just the deeres.
Here's Kubota's BX factory cab in europe
[/IMG]
/ New JD 1000 Series Cab #12
[/IMG]
Which is very odd because as though I have ZERO need for a new lawn mower right now, if someone made me a sub compact with a factory cab to mow with, I'd more than likely be at the dealer tomorrow...
/ New JD 1000 Series Cab #13
If i was to take a wild a**** guess it say that adding $5000 to cover the cab would be a major driving force as to why you dont see them here. Machinery is more costly over there so they probably would notice the increase as much.
And there could be the possibility that the cab could raise the centre of gravity up and open the companies up to litigation as the result of a rollover, especially in the states. And needing to have the cabs ROPS certified. Subcuts arent that stable in the best of times due to their narrow footprint and relatively high centre of gravity.
[/IMG]
Nice! :thumbsup:
Thanks for posting!
/ New JD 1000 Series Cab #16
Yep, the Europeans generally get more optional goodies than we do. My 2001 JD 4200 could be equipped with a heated cab (no AC), two speed rear PTO, a front PTO, along with a mid PTO, and front 3PH..
Here in the USA...no cab, single speed rear PTO, no front PTO, and no front 3PH
Europe also makes them add brake lights, and other car like features they don't do here.
/ New JD 1000 Series Cab #17
It's pretty nice over seas that they can get this. We as Americans are bringing dumbed down to the real truth as to what is happening. Why can't we as Americans get this first. My local Jd dealer don't have a clue as to what is going on. Look at the 1 series . I have their info on this tractor. I happen to have it in my hand. I don't see a front 3 point or a cab option? I am tired of this and I am not going to take it anymore. So for me I'm not buying anything! I don't like sloppy seconds or even thirds. Thanks!
/ New JD 1000 Series Cab #18
Spot on, I think. There is certainly some diff in safety requirements accross the pond. We used to see a lot of european rotary heads for corn choppers, same brand as we had but a boatload cheaper. However missing all of the USA required safety features, drum brakes, etc, etc. Some where valid some not so valid. The pricing is also probably a point too, mfg's look hard at what take rates are and although one would think they would sell the heck out of factory cabs on cuts that may not be the case just yet.
/ New JD 1000 Series Cab #19
If you're meaning the market here for factory cabs wouldn't be justifed. I think JD needs to do an owners poll. They would be very surprised.
Personally,I'm pissed that the Europeans have so much more to choose from.
Greg
/ New JD 1000 Series Cab #20
Greg
x2, It's one thing if they had to completely redesign the tractor, but they have already put it through it's paces. If people want to buy it they will. I don't see the harm in having it here.
