Buying Advice Backhoe for Kubota B3030
/ Backhoe for Kubota B3030 #1
kirklowj
Summit Hill, Pa.
Kubota B3030
Hello Everyone,
I'm not exactly a new member (I've been reading discussions and advice since 2007) but I have not had much time to get involved since I purchased my Kubota B3030 HSD back then. My attachments include:
LA403 FEL
60" MMM
Land Pride 60" landscape rake
Balast Box
I live on 7+ acres (about 2+ acres fairly level and the rest slopped (15-30%)).
I have about 1/3 the property cleared and the rest is wooded. I was thinking of purchasing a backhoe (with subframe) for my tractor but I'm not sure if I want to try and find one used or buy new. Also, would the BH77 fit the tractor or would I have to try and locate a BH75. I know Woods also makes a backhoe that would fit (BH80 I think). Does anyone have any advice or experience with a backhoe for the B3030 HSD.
I would be using the backhoe to dig drainage ditches and remove small stumps etc.
Thanks
/ Backhoe for Kubota B3030 #2
The BH77 will fit your tractor, just have to get the proper sub frame kit. Your dealer should be able to order everything you need, it'll probably be close to $8K though with the hoe, sub frame, bucket(s) etc.
I personally like the Kubota hoe a lot better, but if you do decide to go with a Woods hoe, the BH70 is the one you probably want. The BH80 will physically fit, but it is too much hoe for that size tractor.
/ Backhoe for Kubota B3030 #3
It would be best just to rent an excavator or full size backhoe to complete the job, rather than tying up 8k on a backhoe you only use a couple of times.
I have to agree with you, it would probably be better to hire a contractor to do drainage ditch work etc. plus the room it takes up for storage when not in use. It would be a great attachment to have but not really cost effective.
thanks for your input
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
(4) 12-16.5 Tires (A65640)
(4) 12-16.5 Tires...
Ford 2000 Tractor (A65579)
Ford 2000 Tractor...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
