Kubota B8200 help
/ Kubota B8200 help #1
53GMC
Western North Carolina
Ford 8n, Two Massey Ferguson 20 Industrial, Hinomoto
I am looking at a Kubota B8200. I can have it for free if I can get it, the trick is I will need to pull or drive it across a river. It was on some land someone purchased in my family.
It is manual steering, 2wd, no loader. It's been sitting outside probably all its life and has about 70% of the paint left, what's left is faded. The tires are dry rotted. It has not been ran in 5-10 years.
We took a battery and some starting fluid and tried to start it without any luck.
I took the injector lines off then cranked the engine but there was only small spurts that came out of the lines, how much fuel should come out of the injector lines once they are removed?
Do any of you guys have any tricks to start a diesel engine that has been sitting?
Thanks,
Philip
/ Kubota B8200 help #2
Dump the old fuel and put some fresh in it. New fuel filter and bleed all the lines. I'd also change the oil before I ran it.
/ Kubota B8200 help
The fuel looks and smells good. Does diesel go bad to where it won't run? I know gas will go bad pretty fast, but how about diesel?
/ Kubota B8200 help #4
53GMC,
I have a B9200HST, and have run out of fuel several times.
Push in the fuel shut off knob if it has one. Pull out to stop the engine.
First, remove the fuel line at the input to the filter and see if there is a good fuel flow.
Change out the diesel fuel for fresh diesel.
Get new fuel filter.
Loosen the first injector and turn engine over until fuel flows out. Re tighten the injector. Do the same for all.
Hold key to the left for 20 seconds. Then turn key to start with throttle about 1/4
Works for me every time.
I have a brother that has a house in Hickory NC, and Sunset Beach NC. I am from Dillon, SC
/ Kubota B8200 help
How much fuel should come out of the fuel lines? Thanks
/ Kubota B8200 help #6
very little if you are referring to what gets squirted into the cylinder for each firing.
...and diesel fuel will go bad.
/ Kubota B8200 help
I am talking about the injector lines, NOT the injectors. I took the tube off of the injector.
Do all of the B8200's have a hi-mid-low range, or do they just have 4 gears?
Thanks.
/ Kubota B8200 help #8
Thanks.
I am talking about the injector lines too. very little fuel, much less then a drop of fuel comes out per injection.
I am not familiar with the transmissions available on that model.
/ Kubota B8200 help #10
You should have a good flow to the filter.
If you have loosen the line on the injector, should only be a little bit of fuel while cranking.
You may have to crank for awhile, but only do short crank cycles. Let the starter cool some before trying to start again,
Hit the glow plugs for about 20 to 30 sec before you start.
Not sure if you are talking about hydro, but my B9200 HST has three speed range.
/ Kubota B8200 help
Thanks for the info. Do the injectors gum up easley or should they be fine? It's about a half mile from the truck to the road, carrying more than one battery gets hevey :ashamed: The neighbor across the road is not to happy when we are there :smiley_aafz:
/ Kubota B8200 help #12
I had a B8200 for 12 years. Great, tough little tractor. Mine was 4x4, no PS, no loader(added one later).
They have three ranges, low/med/high. Mine was HST; I think the gear had a 4 speed tranny?
If it has sat for long, then put fresh fuel in. You might change the fuel filter too; it is located on the right side of the engine compartment. It's cheap, and you should be able to get one at NAPA.
You'll need to bleed the fuel system. Someone else already posted how to do that.
They are great little tractors, albeit a little low on power at 19HP. Mine was tough as nails for 12 years that I had it; it was about 12 years old when I got it... I know the guy that bought it from me; it has been working great for him.
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
JMR TREE BOOM (A61572)
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
46" X 51" TRUCK BED SEAT PLATFORM (A64280)
46" X 51" TRUCK...
