Front-End Loader Dropping the bucket
/ Dropping the bucket #1
Kuboy
Kubota B7610
Ok, I had a quick 10 minute review of my used Kabota with a front end loader. Can someone tell me how to drop the front loader via gravity so it hits the pavement without lifting the front end? I know this is easy but I'm just learning.
Thanks to all positive responses.
/ Dropping the bucket #2
Mine goes into the "float" position by pushing the stick all the way forward. You have to push it past the detent for the down movement which lifts the front end. It doesn't take a lot of strong arm effort to get past that detent and just lowers the bucket gently to the ground without lifting. Hope that works for you.
/ Dropping the bucket #3
Yeah, float position will do it or if you are dropping it when you finish just shut the engine off and lower.
/ Dropping the bucket #4
/ Dropping the bucket #5
If your concern is just for parking, then you can do either of the above, or even lower the bucket to the ground, shut down then work the FEL control. As the pressure goes off the system, if the bucket is raised, it will lower; if the bucket is carrying some of the tractor's weight, it will let it down.
If you are looking at scraping position, the float method is probably the best approach.
BOB
/ Dropping the bucket #6
/ Dropping the bucket #7
Cant get that link to work for me
I agree, it does not work. but none of the videos work right now, It did work ok an hour ago. but I am unable to watch any videos from this site at this time. Perhaps try again later.
James K0UA
Thanks for the info. I'll try it. Couldn't see the vid but will look later. One more quick question. I know the little lever in front of the big lever is some kind of lock thing. Can you tell me what it is for?
Thanks again. It really helps to know what the &^^^$ you are doing!
/ Dropping the bucket #10
Videos are working again
James K0UA
Pete,
Thanks for the vid. Fast but I get the picture.
/ Dropping the bucket #13
Kuboy, it's a matter of practicing feathering the joystick so the bucket falls more slowly as it approaches the ground. You'll get used to that fast once you practice.
Jim
/ Dropping the bucket #14
The only time I am tempted to use the bucket lock is when I am doing a lot of backing such as using the rear blade to push snow. The Loader control on my tractor is located next to my right knee which is great for using the loader, but easy to hit with my knee when backing. But even then I don't use it much as then I have to switch it to use the FEL. The dealer said it you are mowing with a brush hog and have the FEL on as a counter balance, you can engage the lock so that you don't accidently stab the bucket into the ground. On my first lap of mowing I use the bucket to fend off spiders hanging from the trees. After that, I guess I could, but usually don't.
2009 CHEVROLET SILVERADO 3500 TOW TRUCK (A65057)
2009 CHEVROLET...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2017 Bobcat T650 Compact Track Loader Skid Steer (A66734)
2017 Bobcat T650...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
