What is the 62D MMM Differences?
/ What is the 62D MMM Differences? #1
PCABE5
Wisconsin
John Deere 4066R Cab and loader
What are the diferences between the 2320's 62D1 and the 25/2720 62D2 MMM deck? I was looking at trading up tractor to tractor but I was told the decks are different and would not interchange.
/ What is the 62D MMM Differences? #2
I suspect that the basic mower decks are the same but the mounting points, and attachment lift mechanisms are different.
/ What is the 62D MMM Differences? #3
PCABE5 Did you ever get an answer about your mower to fit a different machine? I just bought a 62D2 deck and I WILL mount it to my 2320. I just have to figure out what I need to do. I found the deck with a blower/bagger attachment for 2k delivered. I thought it was a good price now I just have to make it fir some how.
I didn't but looking at the two tractors I figured the rear attaching points were different.
/ What is the 62D MMM Differences? #5
The deck bodies are the same. So either deck will mount to the 2320 or 2520/2720 with the correct mounting hardware. The differences are the locations of the gearbox & ramps. The gearbox mounting bracket, drive shaft & belt are different between the 2 decks. There may also be a few other different minor parts also.
/ What is the 62D MMM Differences? #7
thanks greg
I had read that post as well. I have found a couple others also but with very little information.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
Sky Jack SJ8831RT 4x4 Rough Terrain Scissor Lift (A61572)
Sky Jack SJ8831RT...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
E-Z TRAIL HEADER CART (A63291)
E-Z TRAIL HEADER...
