Options for adding lights to a JD 345
/ Options for adding lights to a JD 345 #1
isuhunter
JD 185 Hydro
Wondering what you guys have done to add lighting to your lawn tractors? I purchased a JD 345 and would like to add some lights as I think my cell phone might offer more light than whats currently on it.
/ Options for adding lights to a JD 345 #2
i mounted some clear fog light/driving lights from pep boys for 50 bucks just underneath the jd lights. used the included toggle switch to operate.
Any chance you have a photo?
/ Options for adding lights to a JD 345 #4
unfortunately not bud. I drilled 2 holes through the front grill just underneath the lights. one hole under each factory light after test fitting and then was able to angle the lights 90 degrees. The lights put out incredible amounts of light for plowing compared to the factory lights. kinda ghetto but hey it worked. i dont know what your willing to do but you could also fab up some poles and mount lights on top of them and maont to rear of tractor which would probably light up everything. then just remove the poles when your not using the lights.
