Speedometer
/ Speedometer #1
RFB
None
Sirs,
New (1 month) GL5740HSTC.
Last night while plowing snow I noticed that I could not get the Intellipanel to display mph.
I cycled the entire panel and also tried road speed to no avail. (I am familiar with the system from a previous GL5030HSTC)
Any ideas?
/ Speedometer #2
Sirs,
Any ideas?
GREMLINS:laughing:
/ Speedometer #3
Did it ever display the travel speed? If not the dealership may not have entered the tire size speed coefficient into the dash.
If it did display the travel speed and then stopped it may have encountered a glitch or parameter it didn't like. Every once and a while little glitches surface and the dash just needs to be reprogrammed. It's not as bad as it may sound. A dealership tech can do it in less than an hour assuming there is no hardware issues. Basically it's just having the computer relearn sensor parameters and or reload the tire size.
Is everything else working properly?
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
300 GALLON HYD OIL TANK (A64280)
300 GALLON HYD OIL...
24 x 8.0 x 14 5 Lugs Tires (A61573)
24 x 8.0 x 14 5...
(2) 3.5" X 36" HYD CYLINDERS (A64280)
(2) 3.5" X 36" HYD...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
