Why I love my Fit-Rite Hydraulics Side Link
   / Why I love my Fit-Rite Hydraulics Side Link #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
Why I love my Fit-Rite Hydraulics Side Link.....
-first and foremost...Brian's customer service, is one of the best I've ever seen :thumbsup:
-Easy installation, I didn't order it with the hose kit, as I had spare hoses I could use, instead, I asked Brian what I need, and he not only told me each and every piece, but also right down to the thread type I'll need. It took me about 30-45 minutes to install, including the time it took to plumb in my hoses and fittings. It would have taken me, by best estimate, about 73 seconds to install if I ordered it with the hose kit. :D
-FLOAT! I never thought I would care, or need, or use, the float position. I bought this side link from the person I bought it from, simply because customer service is most important to me, and he gave me the best. I asked way more questions than he probably wanted to answer, but never let me know I was bothering him :laughing: The FLOAT feature works with my valve that has a float detent built in. When using the landscape rake in my rather uneven area's, almost every time I put the rake down, I put it in float, this way as I go over uneven terrain, the rake will follow the contour, rather than staying at whatever contour the tractor is at. I know the 3pt hitch is supposed to float on it's own, but it really does seem to work better with the float on the side link. I don't know why? :confused: I know this will come in handy when snow starts to fall (if it ever does:() and I'm scraping the driveway.
I also use the float on my box blade when i'm dragging material, this way I don't dig up what I'm going over, and instead, the box will follow the contour better than without it.
-Hitching up implements-My 3pt Log splitter is notorious for wanting to aggravate the heck out of me when I'm hitching it up :laughing: When I back up to any of my implements now, before I get off the tractor, I put the valve in float detent. I now have the ability to move the side link side to side of course, as well as in/out with the telescoping links, but also up and down very easily, as I can just push or pull the cylinder in/out of the ram, to make it easy to hook up. No more going back to the tractor and making small adjustments to the levers :thumbsup:
I did a lot of research on side links right here on the forum, as well as got some time on a friends L3400 with top N tilt, to try it out for myself. He has a CCM top n tilt setup which works excellent as well. I was a little skeptical to go with a non check valve type cylinder because of all the great reviews on here I've read about regarding the DPOCV cylinders, as well as the previously mentioned L3400 that I've used. However, now that I've been able to compare the two, and get some time under my belt using my side link, I've come to the conclusion that for me, the only disadvantage I see in not having a check valve, is that if I park my tractor for more than a few hours and leave my implement up in the air, (which normally I put it down) when I come back, it will be a couple inches lower on the right side than it was when I left it. Big deal....
In theory, I think the cylinder 'seep' that people talk about is a valid point, but in practice, having time on both systems, It wouldn't be possible for me to tell the difference.
I'm posting my opinions on my side link for anyone who is interested in my thoughts, however most of the time nobody is :laughing::laughing:
I think the DPOCV cylinders that I used also work great, and I haven't noticed many disadvantages to them, aside from the ability to float. However, I haven't noticed any advantage to them either? I suppose if you have leaky valves then the seep could worsen, but if that's the case, you should probably replace the seals on your valves :laughing:
All that being said, I don't think any one system is 'better' than the other, seems to be whatever your needs are, I'm sure there are some situations where a DPOCV cylinder would be better, I just can't think of any for my specific uses.
I'd be happy to answer any questions I can if anyone has any, and especially if your considering a new side link. I can't comment on the top link yet as I don't have one, but give me another month or two and I will. :D
I hope someone found this informative. :thumbsup:
Happy Tractoring,
-Matt
Sorry I don't have more pics...
If your considering buying a side link, I'd highly recommend taking the plunge, no matter which one you go with. :thumbsup:
   / Why I love my Fit-Rite Hydraulics Side Link #2
I think Brian's links would be hard to beat.:thumbsup: Customer service as good as his is hard to find. Glad it worked out for you and Brian.
   / Why I love my Fit-Rite Hydraulics Side Link #3
Congrats on your side link :thumbsup: You will like it more and more as time goes on.
I love mine also. It looks alot like yours :D
Puts using a rear blade at a whole other level.
   / Why I love my Fit-Rite Hydraulics Side Link #4
Matt, thanks for the review. It was no problem answering any and all questions that I was able to answer. Hopefully your description will help others understand the benefit of having a valve with float position. :cool:
Matt, since you had purchased your side link, I have started offering hydraulic flow restrictors. These restrictors make fine adjustments that need to be made much much easier. Only $10. :thumbsup: Maybe I'll send 2 when you order your top link and hose kit. ;)
   / Why I love my Fit-Rite Hydraulics Side Link #5
It is because the hyd side link allows the implement to float rotationally. The 3pt allows only straight up/dn float ... altho some tractors have an optional mechanical arrangement on the lift links where you can choose to allow some rotational float. Rotational float is a valuable option - as youve found.
larry
   / Why I love my Fit-Rite Hydraulics Side Link #6
larry
Now all I have to do is to get people to understand this.
   / Why I love my Fit-Rite Hydraulics Side Link #7
Originally Posted by SPYDERLK
It is because the hyd side link allows the implement to float rotationally. The 3pt allows only straight up/dn float ... altho some tractors have an optional mechanical arrangement on the lift links where you can choose to allow some rotational float. Rotational float is a valuable option - as youve found.larry
If imagination wont suffice perhaps a video would.:confused3:
larry
   / Why I love my Fit-Rite Hydraulics Side Link #8
larry
That is actually the plan. Just didn't want it out of the bag just yet. Hope to have it done and up next month. Should show and answer a lot of questions for people. You know what they say, a picture is worth a thousand words. IF that is true, what is a video worth? Stay tuned. ;)
Brian,
I'd like to order that top link. :D
I think we decided on the
a cat 1 top link built with a 2 1/2" dia x 12" stroke cylinder having a 1 1/2" dia rod with a working length of 21 1/2"- 33 1/2"
How do the flow restrictor's work, is that the same as a needle valve that I've heard about? Is it one per cylinder or one per hose? (meaning 2 per cylinder?)
   / Why I love my Fit-Rite Hydraulics Side Link #10
Brian,
I am using Brians flow restrictors and they work GREAT made all the difference in the movement of the implement. :thumbsup:
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
