Oil & Fuel Kubota B7510 Service
   / Kubota B7510 Service #1
STT
Kubota B7510 FEL
I have looked and looked but I cannot find the exact location of the rear drain plug or oil strainer for the hydraulic UDT fluid (I have searched the web and my tractor). I have found all kinds of pictures of B-Series tractors. I have also been to Messicks website and looked at those pictures. I have seen a picture of the oil strainer removed. None of these pics show the exact location of the drain or strainer.
Looks like maybe one on each side of rear-end and maybe 1 mid PTO, but strainer, I have no clue???????
Before I just start pulling out bolts:
Where is the exact location of the rear drain/drains as well as the oil strainer on the B-7510DT non-HSD? I just bought mine (no manual) and am trying to get everything "up to par" before I put it through to much. Pictures would not only be helpful but awesome..........
Thanks in advance..........
I believe from further reading I have located the 3 drains however, the strainer still alludes me. I now know what it looks like and a 26mm socket fits it. However, can't find the location.
   / Kubota B7510 Service #3
The strainer is on the right side of the tranny (if sitting in the seat) just behind the filter.
There is a large bolt that secures a piece of 1 in tubing to the tranny. The strainer is on the inside end of the bolt. Just follow the tube back to the end to find the large bolt. The book says rince the strainer in nonflammable solvent to completely clean off metal filings. This piece of tubing is the suction line. The drains on my 7610hst are on either side of the tranny at the lowest point and one on the side of the front pto case on the left side. Good luck. ps the factory manual covers the b7410, b7510 and b7610, both hydrostatic and manual tranny units.
Messicks videos/pics while good, only cover B-series in general and not specifically the b7510. I actually think they use b7800 for reference. Thanks for your responses though.
   / Kubota B7510 Service #6
But, if I remember correctly, Messicks will email you a parts diagram of your specific machine. Those exploded views show great stuff. I believe they used to have them up, online, but can no longer do so, as per Kubota rules. Still, pretty sure they'll email attach you the .pdf files. Great help to me one time on something. Can't remember now what. ;)
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A57880)
2019 TOYOTA...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
