Traction Near death experience!
   / Near death experience! #12
Good reminder to all!
   / Near death experience! #13
Jinman mentioned this years ago. 4WD braking. I thought it was some of the best advice I ever read. Keeps the pucker factor to a minimum. :D
   / Near death experience! #14
Ken, I read your post several days ago and can identify with the horror and helplessness you felt in those few seconds. Scary stuff!
   / Near death experience! #15
Always, always, always drop the implement and let it dig in the ground to help you stop, it reduces the dead weight your tires are trying to stop as well.
   / Near death experience! #16
I once had to jamb the brakes and throw it into 4wd.
   / Near death experience! #17
Wow, just yesterday, I was going down my driveway...steep, with four old railroad ties on the bucket forks. Soon as I started down I applied the brakes. I slid almost all the way down. Lucky for me I was able to somewhat control the direction of the slide. I was in 2 wheel drive on my L3130. Guess I learned a little more in this post. Thanks to all.....
   / Near death experience! #19
If you got 4WD engaged that can help in those situations, for sure.
But you can get in that exact situation if you *don't* have four wheel drive as well. The thing to do if it happens on a 2WD tractor (which includes 4WD, but not engaged) is to push in the clutch! Then pump the brakes like you would in any sliding/skidding situation. The trick is to try to get the rear wheels turning enough to straighten out the tractor - while keeping your speed as slow as possible, of course...
   / Near death experience! #20
That's a good way to tear something up. If you hit the brakes and lock the rear wheels then try to engage 4x4 with the front wheels turning your going to break something very expensive...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
202481 (A54757)
202481 (A54757)
2015 Peterbilt 567 Wet Kit T/A Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
