buying 5" angle grinder advise
/ buying 5" angle grinder advise #41
/ buying 5" angle grinder advise #42
It's a 7" 15 amp Makita. Used it a bit last night with a grinding wheel. I like it. Gives me the willies though without a guard on that wheel. I think I'm going to get a course grit flap wheel for it.
/ buying 5" angle grinder advise #43
I like 6" so I can use cutting disks with longer wear and higher surface speed. I use a Metabo, but any good grinder will do.
Agree on the 6"....the slicer wheels can cut deeper and last longer.
At work we buy a hundred slicer wheels at a time and get a free Metabo grinder.
I've burned up many a dewalt the metabos are a tough nut.
At Lowes the other day they had a two pack of porter cable 4-1/2" grinders on sale for 90 dollars.
When I'm welding and fabricating I like to have at least three set up if not four,
0ne with a slicer wheel, one with a wire brush, one with a 6" hard grinding wheel, and one with a 50 grit soft disk.
/ buying 5" angle grinder advise #45
I dont agree. I find the best way to cut (other then a porta-band) is a 7'' grinder with a walter zipcut. Another inch of wheel, and much more power.
/ buying 5" angle grinder advise #46
The best angle grinder I've seen is the 7" Sioux 1285. And when I was repairing them, one of my customers send me two because employees had removed the guards and threw them away. Then OSHA visited.:laughing: Those danged guards cost $130 each.:D
What exactly is a slicer wheel??? Never heard of that before. Is it a zip cut??
/ buying 5" angle grinder advise #49
Not sure what a zip cut is, but a slicer wheel is just a cut-off wheel. Like on a air die grinder, only bigger.
In other words, pretty much just a thin, flat grinding disc. Made for cutting things off.
/ buying 5" angle grinder advise #50
Up north here, we always call then a zip cut. Zip cut is the walter line of cutting wheels, but that name has been applied to all cut off wheels.
/ buying 5" angle grinder advise #51
Looks like this deal is getting worse all the time. I don't have the inner flange and matching outer locknut to run typical 7/8 arbor cutoff wheels. That's another $15.
I should have just bought the grinder new.
Ian
/ buying 5" angle grinder advise #52
Ian
Ouch. I find used makitas normally go for way too much. At the pawn shop I get some of my used tools at, they had a beat up makita 7 inch with no guard, for $60. They also had a black&decker pro 7 inch with everything but the wrench, for $45. (I got the B&D)The B&D would probably last longer as well. If I was getting another 7 inch, it would be either a black and decker wildcat, or a skil all metal 7 inch.
/ buying 5" angle grinder advise #53
So kinda like crescent wrenches, channel locks, vise grips, etc.
/ buying 5" angle grinder advise #56
Metabo has a variable speed model with "AutoBalancer" technology. This should be the ultimate grinder.
[ame=http://www.youtube.com/watch?v=3RR-lhiXigE]Metabo angle grinders with and without AUTOBALANCER feature - YouTube[/ame]
deereman75 said:
Pampers..... Is the first thing that come to mind following suit, I have a 7 month old ... Similax is another
iDrive TDS-2010H...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
24in Mini Excavator Bucket Attachment (A61572)
24in Mini...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2020 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A59911)
2020 INTERNATIONAL...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
