ignition switch replacment
/ ignition switch replacment #1
Smoody
South Carolina
YM226D
Has anyone used a ignition switch from advanced or auto zone instead of a yanmar one?
Also can someone explain this, while checking out a friend's ym2000 that would not crank pretty sure it's a bad switch, taking a piece of wire from battery + to selonoid it clicks, taking wire from battery + to starter it turns over. Here's what got me, using a set of jumper cables to the starter nothing happens, but using a small wire to starter turns it, why? The small wire almost melts to the post so we thought to try a jumper cable but get nothing, and yes the cables are good.
/ ignition switch replacment #2
Still CRS half the time:confused: But on my ym2000. Before I got Hurt. When it was doing that I replaced " Battery Ground Cable to the Frame" I'm pretty sure thats what it was. ;)
/ ignition switch replacment #4
I did, easy to do. Take one wire at a time off. Works good. bill
Further explanation:
I used a multi-meter and get 12.6V on battery, I get 12.6V at the starter, I also get 12.6V at the ignition switch "battery" post. With the key turned in the ON position no dash lights display and I only read .01V on the "IGN" post wire on the ignition switch. So my guess is inside the switch is bad and not passing power? wouldn't that point to the switch?
I get no reading on the solenoid post coming from ignition switch.
/ ignition switch replacment #6
Are you measuring the voltage with the switch in the on position or the crank postion? On postion should have no voltage to the ign post wire, crank position should have 12.6v.
no key in the ignition i get 12.6V on the post coming from the battery, key in turned to the ON position I get no reading on the "battery" post and only .01V on the crank position ("starter" post going to solenoid) so it is not passing 12.6V to the crank position.
so its the switch, thanks:thumbsup:
/ ignition switch replacment #8
This is what I just came up with. I needed to put a charge on the battery were it been sitting cold:) Neg. on the V-meter to the Grnd on the Battery. I showed 12.5 Pos. on the starter. and 12.5 0n the Pos. White/R on the Ing. switch with the Key in the on position the same Readings. On the starter Solenoid key in the on Position. On the Blk/Grn small wire on the top "0" with the key turned to the Start position 12.2 on the Blk/Grn tn the Solenoid. On the Starter Pos. from the battery 12.5 on the big pole next to it on the Starter motor "0" until you turn the "Swtch to the Start Pos." 12.2 I checked all of that with the decompression on. After all checked Good Enough :laughing: Hit my TS 10 sec. and it fired right up no smoke NODDA trace wich I set my throttle guessing to 1500 rpms. which was dead on the money.;)
/ ignition switch replacment #9
No smoke? Cary your tractor is amazing! How in the world do you crank a cold deisel and have no smoke? Even my uncles JD when it was newer still had a puff at start up?
Mine will belch the black in a puff then have a lighter color till it runs for a min or so and warms, not bad but if you look you can see it.
/ ignition switch replacment #10
No!!! It's sweet :D It's done it before esp. in the summer or higher temperatures on cold starts not using the TS. but it's not much. The Typical Small Blk. puff of smoke on a Diesel. Also under a Load and throttle it up your get a puff or so. When I went over to Steve's at Spalding tractor and first cranked it up. Looking at the Orig. condition of it compared to the Refurbished Tractors. I had to ask were he got from. He wouldn't elaborate :p Honestly he just said he didn't know. With his add being UTDA I was just shopping or "kickin tires". Did'nt even bring a Trailer. I left Him A Check though and I'd be back to pick it up.;)
/ ignition switch replacment #11
When i load mine up, like bushhoggin 4-5ft tall grass or pulling my disk with 250lb on top with the gangs sunk in the dirt it will put out the smoke as it strains to pull it. Nothing im worried about honestly. I have seen some way worse on youtube of folks yanmars that were newer than mine rolling way more smoke on less work than mine was doing.
Normal bushogging just faint smoke if you look right in the sun and concentrate on seeing it. Will puff a bit if you hit a thick clump or some big branches or something in the field. But i bushhog maybe 7 acres 2-3x a year and disk my 1-2 acre foodflot twice a year.
/ ignition switch replacment #12
7acres. 0n the BH. Thats it? That's not much Fun. Buy you a FM. I do that easy Bi Wkly. I don't get any smoke and don't use much fuel Either. The sound of the 2cyl. Yammer Hammering along doesn't bother me a bit. I kind of like it :cool:
/ ignition switch replacment #13
Not sure how much it is? Its not where i live so i have to do it all on a weekend i go there. I get smoke when its heavy stuff, nothing im concerned about. Thats all i get im happy, after hearing others stories about their vn's. I also have a 3pt valve thats a bit leaky that i need to go into and see if i can replace an o ring or something, just a bit of a leakdown if you cut engine off with 3pt up, not the main piston as when you turn the lockout it dont fall.
I dont mind the hammer either. But as far as the acerage, id have to take my gps to figure it out one time. I dont cut it but a few times a year so when i do its pretty tall. I can cut about an acre an hour or there abouts mabe a bit longer sometimes maybe a few mins faster sometimes. It will take me all day to cut my fields if i do it all at once so it may be more. Im not talking about a daylight to dark day, im not a farmer afterall.
/ ignition switch replacment #14
If I have to do any brush cutting I use a 7'BH with a JD 5103.:thumbsup: My Ym2000 Which when I found out it was basicly the US. JD.Ym240 is why I even bothered to look at them. Found mine and bought it. Seen and looked at a couple of 240's and new it would work with the Woods/Frontier FM but both were in rough condition. I knew over the yrs. I do to much for Lawn mowers even use a JD with a Kohler that stays in the Shop. That or "Garden Tractor" and way to much for a Zero turn. I get to watch my neighbor get beat to death on his :laughing: They're great for a Sub.Div. Lot. IMO. Also let me add that now with both Tractors with FM's never even use the BH but Rarely The mashino is actually set up similar to a BH with the blades on a Pin when your in the rough stuff.
2022 CATERPILLAR 313 EXCAVATOR (A65056)
2022 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2006 Ford F-750 Terex Commander C4047 Digger Derrick Truck (A68183)
2006 Ford F-750...
AUTOMATIC TRANSMISSION / TRANSFER CASE (A68842)
AUTOMATIC...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
