Build a pump
/ Build a pump #1
Whatswrong
Gold Member
land of living sky
B434 ,V 700 and 1086
If you couple a 40cc motor to a 315cc motor directly than put 8 galons per minute of oil into the 40 cc would the 315cc pump approximatly 32 gallons per minute under no pressure/open line .I have no idea if you could get 32 gallons through the 1/2 inch ports.
/ Build a pump #2
If my math is correct the 40 cc motor would turn at 757 RPM with 8 GPM flow. The 315 cc motor at 757 RPM would produce 63 GPM
or 315/40 = 7.88
7.88 * 8 = 63
32 GPM through 1/2 inch ports would have velocity around 35 Feet per Second.
recommended max velocity for a pump inlet is 4 Feet per Second
Roy
/ Build a pump
Thanks for the insight I'm trying to visualize if it is as simple as reducing the input to bring the output into an acceptable range.
/ Build a pump #4
yes, if you can develop enough torque to drive the larger pump/motor. May want to also confirm that your components will operate at that low of RPM.
Roy
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
2013 Tahoe Q4 Boat with 2013Tracker 18ft S/A Boat Trailer (A61569)
2013 Tahoe Q4 Boat...
2016 Buick Regal Sedan (A61569)
2016 Buick Regal...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
More info coming soon! (A56859)
More info coming...
2025 ELECTRIC GOLF CART (A61569)
2025 ELECTRIC GOLF...
