FarmTrac 535 Tappet Adjust
/ FarmTrac 535 Tappet Adjust #1
Tex5String
Member
San Antonio TX area
FarmTrac 535
Can I rotate the flywheel through the small inspection hole on the left of the engine, or must I remove the starter on the right side?
The manual says nothing on this question, just advises rotating to TDC for cyl. #1, etc.
This is a 2005 model, 3-cylinder.
Thanks for any pointers!
/ FarmTrac 535 Tappet Adjust #2
I do not know your tractor and this may be a stupid question but can you not rotate the engine with the crankshaft bolt on the front of the engine, the one that holds the belt pulley on the crank? That is how I adjusted my valves on a mitsubishi engine...
Good looking horse in your avatar, Dallas!
My previous tractor was a 1949 Ferguson with a 4-cyl Continental engine. Everything was wide open and easy to access. The Farmtrac front engine area is really tight with power steering pump, very tight clearance to fan, lots of tin outside, etc. Maybe I can access the nut from below -- have to try it with my wife watching the tappets to tell me when cyl #1 reaches TDC.
Thank you for your suggestion!
/ FarmTrac 535 Tappet Adjust #5
I was able to lay underneath my Farmtrac 60 3 cyl diesel (same as the 555) and reach the big bolt on the crankshaft pulley and turn the engine. Hardest part was finding the timing mark on the rusty flywheel. :mad:
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
204549 (A52707)
204549 (A52707)
1006 (A61166)
1006 (A61166)
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
