Diesel additive
/ Diesel additive #1
16valex
NY
bx23
The tractor got kicked out of the garage for the first time, concerning about diesel getting jelly, what type of additive do you guys use in your tank? Thank you in advance.
/ Diesel additive #3
I use Power Service and have never had any problems.
/ Diesel additive #4
I use power service in my kubota, isuzu and duramax diesels!
/ Diesel additive #5
I use this stuff from a company called Howes, napa sells it havent had any problems for yrs, so guess it works.
/ Diesel additive #6
I also use Howes Diesel fuel treatment - it got better reviews on a website than PS.. You can get it at Northern Tool and a lot of truck stops..
Brian
/ Diesel additive #7
Optilube XPD is the most highly rated in studies for anti-wear. It also has a variety of other benefits including anti-gel.
Read more here:
Diesel Fuel Improver
Problem is, you have to buy it online. I can't find any local dealers.
/ Diesel additive #8
Standyne. Have used it 12 months of the year since the L3940 was new in 2007. Never a cold day or hot day problem. She fires up everytime. :thumbsup:
/ Diesel additive #9
i use lucas antigel year round.keeps everything lubed up...i'm surprised i havent heard any body using lucas products.isn't lucas usa made
/ Diesel additive #10
I use Power Service (white bottle) in my Kubota and my '97 Ford diesel year round.
Because the Ford will sit outside all winter without being used, I also treated it with Power Service 911 as a little added insurance against gelling along with some PS BioKleen to help prevent algae in the tank.
/ Diesel additive #11
i use power service with cetain boost. never had any problems gelling and been using it for 6 years here in northern pa. it says it won't void manufactures warrenty when used as directed, so i put confidence in that. it also cleans injectors and lubricates fuel pump and such. since ultra low sulfer diesel came out (both on road and off road) i have been thinking of using the power service additive year round to help with lubrication in fuel pump/system.
/ Diesel additive
Thank you folks. I'm going to get me some Power Service since it can be obtained locally.
/ Diesel additive #13
I've used Lucas for years. My cousin's company rebuilds turbo & fuel pumps. He suggested it to me. I've used the oil treatment in high hour engines also.
/ Diesel additive #14
Good luck..If you pull UOA's watch out since you will not use Power Service anymore if you do. Watch Bearing wear and will do not to drop NOX soot levels.
/ Diesel additive #15
What he said!!- no fun when the F-350 [still our primary plowing vehicle] won't start up....
We've put the PS white bottle stuff in as we fill the the tanks since day one, and never [knock wood- my head will do] had any gelling or starting problems...
Ditto Stabil for our gas equipment...
/ Diesel additive #17
I run power service in all my tractors, have for years. NO PROBLEMS
/ Diesel additive #18
Power Service works for me. Run some year round in my diesels.My old Cummins powered pickups [12valves] loved the stuff.
/ Diesel additive #19
?????= please explain your meaning...
Seriously, please?
At a very high level - What they mean is that others have experienced PS causing certain chemical/metal levels to go outside of acceptable limits when they ran a Used Oil Analysis. Once they stopped using PS the levels fell back into the acceptable levels..
If you need the gory details - they will have to give them to you, its over my head.. hehe
Brian
/ Diesel additive #20
Brian
Even with normal dosage rates it was high. I just use MMO and Neutra 131 at times.
2014 Screen USA TROM 6090 Trommel Screener (A61572)
2014 Screen USA...
2008 Toyota Rav4 SUV (A61574)
2008 Toyota Rav4...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2016 Autocar Xpeditor T/A New Way 31ASL 31 CuYd Side Loader Garbage Truck (A61573)
2016 Autocar...
Case Titan 3530 (A63688)
Case Titan 3530...
2015 HYUNDAI HX220L EXCAVATOR (A64279)
2015 HYUNDAI...
