Buying Advice Komatsu D20?
/ Komatsu D20? #1
dntfxr
north Louisiana
Ford, LS
Hey folks, I'm looking for any advice on these machines. I've come to the realization that I need a dozer to get the work done on our homestead. We have 42 acres that need quite a bit of dirt work done before we can move out there. I know these are small dozers but I like the fact that they are easy to transport too (we have another 40acres in MS that still has lots of trees down from Katrina). I know a machine this size has its limitations but I'm looking for any experience or advice on these tractors. I found one I want to look at this Saturday with new clutches and undercarriage. It looks pretty nice but anything else peculiar to these to watch out for?
Thanks
/ Komatsu D20? #2
I believe the D20s are all direct drive clutch machines. Not a negative, just what differentiates them from the D21s which are powershift units.
I've looked at these small machines out of curiosity, but, I keep coming back to the conclusion that they're probably too small to do very much serious dirt work. A 40-50hp tractor with loader and box blade or dirt pan would seem to be just as capable and certainly more versatile, transportable, and maintainable.
You can snag a D20 or Furukawa equivalent or a Mitsu BD2 for about the same money these days. Like I say, for the weight and money, I keep thinking a good mid-size tractor will pay back more in the end.
I'm finding it hard to justify a tracked dozer vs. a regular farm tractor up until you hit the 70hp range where the tracked rigs really began to outweigh and outperform the rubber-tired tractor in terms of production. Might even consider an tracker skid steer within this area.
Anyway, just things I've thought about.
/ Komatsu D20?
Thanks for the reply, definitely food for thought. I've been doing some of the work with my boxblade and it really moves more dirt than I expected but I have a whole lot more to go. I need to raise my house pad area around 3 feet and raise a 200' section of driveway about 2 feet. I'm planning on making a pond and using that dirt for my fill. I'd considered a small dirt pan for my tractor but I really figured the 8.5' dozer blade would be more effective and might save a step by not having to plow the dirt first. Not to mention they are pretty proud of the dirt pans I've priced and I don't have remotes on my tractor. Hopefully some will chime in with their experience on dozers of this size.
/ Komatsu D20? #5
Several years ago I was looking for a Komatsu D20/21 for use on the farm for various tasks (dirt moving, clearing, etc) and encountered much of the same questions (i.e. how much work can a little dozer do?).
I ended up finding an old Case 310G dozer really close and pretty cheap, so I bought it. Now it's probably a lot cruder and obviously older than the Komatsu, but it's got an 8' blade and weights about 8 or 9 tons (I don't know how mucht he Komatsu weighs).
At any rate, I never cease to be impressed with the amount of work I can accomplish with the little dozer. I've got a Kioti DK45 with loader/backhoe/boxblade/etc. and I can move 10 times the amount of dirt with dozer as I can with tractor. When I was finishing grading around our new house, I used the tractor and box blade to try to cut down a bank. That was about the time that I got the dozer and tried it - man what a difference. The weight and the tracks make a 30 hp dozer capable of what a 75 hp tractor (or more) can do.
I also use it for a lot of clearing and cleaning up burn piles - and it can push way more brush/trees/etc. than a comparable wheeled tractor - plus, I never have to worry about flat tires!
Now I would not say for one minute that a little dozer is more versatile than a tractor, but it is (in my opinion) a lot better at pushing dirt short distances and pushing trees/debris. I think it's best to have both if it is feasible (given how much money it costs to have both). I think that my dozer has easily paid for itself during the time that I've had it - I've cleared brush/trees, dug a small pond, helped dig a bigger pond, etc. I've had to do basic repairs and upgrades, but nothing that any weekend mechanic can't fix.
Good luck with whatever you decide to do. Take care.
/ Komatsu D20? #6
I have been checking out the Komatsu D-20, and some of the small John Deere 350's and my conclusion is that they are not big enough to do much more than finish grading etc. They are also expensive to fix, if you can't do your own wrenching. My personal plan now is to save up for a low hours 60-70 HP tracked skid steer. They are more versatile, and easy to transport. If you ever get a chance to watch a good operator do some grading with one you will be impressed.
/ Komatsu D20? #7
i really like my older case 450. i think its in the 50hp range and around 10k# with 6 way blade. It hauls really nice on my 10k low deck equipment trailer behind my 3/4 ton dodge. Truck trailer and dozer weighed 20360# on the local cat scale. it makes maintaining and building my mx track easy.
/ Komatsu D20? #8
I demo'd a D-20, probably 15 years ago. We were looking for something small to replace the ole' 450C Case. We did a lot of channel work with the 450, and placed a lot of stone under bridges, where flooding had scoured the abutments.
I didn't care for the direct drive. I was doing some finish work on a job, and snagged a stump, no more than 2"-3", that the larger dozers had missed. It literally threw the dozer sideways, and killed the engine, as I was grading with the blade at approx. 30コ angle.
They are pretty light, in comparison to HP. It seemd to have plenty of power, but too much for it's weight. It would literally power out (spin), if you tried to cut hard dirt. Possibly a winch on the back may help that issue.
Guess I was just used to the Case's we had, the all did have winches on them.
I could see it's use in a housing project, finish grading loose dirt, in close area's, but not much more than that
They may not be top of the line, but I liked the Case dozer's, simply for the fact you can power each track separate from the other. Both in low for power. One in neutral for a slow turn, or one in high to make a power turn, not just feathering, or killing a track with a steering clutch. Both in high, to tram back on a long push, at lower RPM's, or just to get across, or out of a soft spot, to get torque to the tracks, not power.
Getting aggresive corner bits on any machine makes a world of difference. Angling, and tilting the blade, making it act somewhat like a plow can rip some mighty hard stuff, once they are sharp. I have ripped a lot of semi-hard shale rock with the 450C. The 850 models we had did better.
The only drawbacks I saw with the older Case dozer's, was the dry brakes. Being we did a lot of work in streams, water and sedimant got in the brake housings, and rusted the steel balls in the brake actuators.
/ Komatsu D20? #9
:thumbsup:
/ Komatsu D20?
Thanks for the responses guys. I was kind of thinking the d20 would be better than the d21 for putting the power to the ground but it may still be a little light in the arse. I'm gonna go demo it tomorrow and see what it'll do. I'd still think it would out work a skid steer but maybe I'm wrong. The projects I have lined up for it won't be that big, I just hired out most of the big stuff to a guy with a d6 high track and a 320 excavator. Mostly what I have left will be grading and finish work really. I also will rent an excavator for digging out the deep end of my pond. I was surprised at the weekly rates, they aren't bad at all. I can get a Volvo ecr 88 for less than 1200 a week and a ecr 55 for less than 800. I need to take some pics and start a homestead thread in the projects forum!
/ Komatsu D20?
Went and checked it out and it followed me home! It is small but I was impressed with what it did. It has brand new sprockets, idlers, pins, steering clutches and rebuilt track tensioners. It starts right up runs good, has strong hydraulics and no leaks. There is an older repair on the blade c-frame where they welded some plates on it and I'll probably clean it up and put some prettier beads on it. She's a little rough around the edges but mechanically sound. I'll try to snap some pics tomorrow and I may even get some seat time.
/ Komatsu D20? #12
Thanks
We own a D31p overall good dozer,still can put on GN and pull with one-ton p/u. I will say its too small sometime on ranch,did clean pond out this year and done some fence-line cleaning couldnt imagine going any smaller,had hard enough time with the 31.But beats a shovel.Had to do little work on tensioners,does use little hyd oil,but only gave 6500 2 yrs ago,already paid for itself,it cranks right up everytime and gets the job done....
/ Komatsu D20?
Well I got my baby dozer home and got a couple hrs on it this evening. Granted it's the only dozer I've ever run but I'm impressed with what I got accomplished in that short time. I got a small pad pushed up for my electric transformer, pushed a 6" tree over, and moved a burn pile to another spot. Then I got in the slough and opened it up so it would drain down to the pond and pushed a lot of mud out so it would stay drained and dry. I must say that is the job this little dozer is made for- getting in swampy areas and pushing without getting stuck. The swamp tracks and light weight really allow it to go just about anywhere. I have no doubt a 4wd tractor would have got stuck where I was at today. Here's a couple pics of the dozer before I got in the mud, I'll take some more pics of the slough I dug out tomorrow.
/ Komatsu D20? #14
Been following the thread, congrats on the purchase! I was in the same boat a few years ago, statred looking at 20's & 21's, but realized they were too small for what I needed. Ended up with a Komatsu D38, around 10 tons. Works great for me, could use a bit larger but that's always the story.
Looks like for your application, you hit the nail on the head....enjoy the seat time!!
/ Komatsu D20? #15
Yes, they will! They do great for finishing work but if your building up a house pad 3' or a 1000' driveway you might want to look at something else. My brother had one for about two years, very handy little machines and the direct drive is very reliable. Go drive it and work it hard before you buy it you'll never know until you do. :thumbsup:
/ Komatsu D20?
Thanks guys. I put it to work pretty good today. I really got a lot done and I'm impressed with what it can do. I know a bigger dozer would do the job faster but it also would have probably got stuck today. Besides, it already followed me home! ; ) I had hired out the initial clearing and the operator got his D6 stuck 4 times, had to bring his 320c hoe to get it out. Today I mostly improved drainage around the house pad and graded a nice slope to the yard. There is really a lot of mud in some areas, mainly due to piles of dirt left in the wrong spots from the logging years ago. I also pushed a good portion of a hill to the pad site. I raised the pad by about one foot today. Just a couple more to go. From here it will get more fun though, I'll start getting my dirt from the future pond site. It will be longer pushes and slower going I'm sure. And the driveway will be even farther away. I may just push the dirt into piles and rent a dump truck and loader to get it where I need it. I forgot to take pictures but I'll snap some tomorrow.
/ Komatsu D20? #17
Congrats on your purchase - you're now a member of the "little dozer" club. Guys in the "no dozer" club and the "big dozer" club will tell you all kinds of things that you can't do, but if you don't know that you can't, a lot of times, you can!
Not taking shots at the guys who belittle small dozers (pun intended) - there is certainly no comparison between a Komatsu D20/Case 310/etc. and a Case 1150 or Cat D6. But when you compare a small dozer to a small tractor or skid steer, for pure dirtmoving/clearing power, the dozer will win every time. You will find that you can likely do everything that you need to do with the little dozer - it may just take a while. I discovered when we cleaned out my big pond a couple of years ago that I could drive my little dozer in the muddy areas of the pond where the larger dozer (Case 850) got stuck).
Good luck, be careful, have fun, take care.
/ Komatsu D20?
Thanks Rtimgray, I'm enjoying it so far. I think you are spot on with the capabilities and it just taking a little bit longer than a big machine. Another plus I'm figuring out is it only burns around 1/2 gal of diesel per hr. I got a few pics of the work I did day before yesterday, they really show how wet some spots were. Also I got a before and after shot of the small hill I'm cutting down for my fill. The before shows the contractors cat 320 on it and after is what I cut down in an afternoon. Good news is we got 2" of rain yesterday and everything is draining properly now!
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
