CK30 cold start
/ CK30 cold start
Success!!!!! so I went out and tested for power to the glow plugs...after finally located them:laughing:, found I had power to them,so disconnected the power supply and metal strip from the first 2 glow plugs, #1 test 0 ohms, #2 & 3 both wer.7ohms so thanfully it was #1 as it is the easiest to get at.
Removed the glow plug which I found had major black fouling on the tip since it wasn't working. Took it in to the local NAPA but they were unable to match it up so had to go to the Bobcat dealer as I have no Kioti dealer nearby. Picked up a #6696044 Bobcat plug (numbers were exact as original kioti) ...was a little shock at the $39 price tag!
So just got it done and test fired it with one cyle of the plugs and she fired off on ALL cylinders!!! YES!!!!
Thanks for all your help gang!!!!!!!!
GT
/ CK30 cold start #23
All fixed and it should be much nicer to start when cold. Depending on the hours, a $39 fix seems pretty cheap.
/ CK30 cold start
Ok,ok....so I'm a tight wad:laughing::laughing: ....your right I'll take a $39 fix any day.
Took it out today to pull out some fallen trees,temp 35f ,1 cycle and off she went...life is good!
/ CK30 cold start #25
You got more for the $39 than you realize. Now you are a TBN glow plug expert:thumbsup: Mechanics had to pay to go to school to learn how to test them. :laughing::laughing:
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
UNUSED FUTURE TB47 FORKLIFT TELESCOPIC BOOM (A65055)
UNUSED FUTURE TB47...
