Tractor for 4 acre farm
/ Tractor for 4 acre farm #1
Jfroche
I have recently bought an old farm with 4acres of land.
I have very little knowledge of tractors and would like advice on a suitable tractor to buy. Have been looking online and spoken to friends who have suggested I look at kubota.
Tractor will be used mainly to mow grass but also for other general work
Will be looking at second hand market and have limited budget.
Does anyone have any suggestions?
/ Tractor for 4 acre farm #2
If mowing is the primary use, the BX is tough to beat, a nice used TLB with deck can usually be found in the 9-12k range in the North East
/ Tractor for 4 acre farm #3
How about some more information ?
Location - state - county etc?
Snow Removal - tilling a garden - building walls - moving rocks ?
Lot Topography - hilly - flat - wet - ledge?
Goals/needs/more important "wants"?
Budget ? $10K $5K ?
Kubota ranges from lawn tractor to 100 HP farm tractor, and there are many units that can work for 4 acres, but if Kobota a BX23 with backhoe and mower can be found used for $12K range or if just a mower and a loader (FEL) maybe $8-9K
/ Tractor for 4 acre farm #4
4 acres? Look at a Craftsman.
/ Tractor for 4 acre farm #7
Kubota BX 25, I have 4-5 acres around the house that it has been a real workhorse for. Lot of implements for a 3PT hitch. I put 300 hours on last year doing lots of various jobs. Once you have the BH you will find lots of uses, even ballast aginst the FEL. I considred a mid mount mower but decided my landscaping has too many tight corners to do effeciently and I have a good craftsman rider. Brush mower was a god send for the fringe bramble/blackberry patches.
Limited resources forced me to buy new. Financing a used one is dicey and much higher interest rate and shoter terms. All the compact tractors now have $0 down, $0 interest for five years. Tractor and implements ($24K) is just over $400/mo.
You can save at the most 25% buying used. They really hold their value. I looked at probably 25 and found a real mixed bag. Guys said only X hours never been stored outside, faithful maintenance; a lot of lies in the mix if you know machinery and what to look for. 7 years old, all original you are buying some soon heavy expenses regardless of hours; tires, hoses, seals. Low hours are worse on a diesel engine than medium high hours. Probably never warmed up to drive out all the moisture in lubricants and fuel. What seems a minor engine/tranny problem can rapidly be way over $1K and up from there.
Ron
/ Tractor for 4 acre farm #8
2 websites that are a good source for used tractor priceing...
MachineFinder.com TractorHouse.com.
Enjoy your search.
/ Tractor for 4 acre farm #9
you looking new or used or used / classic / antique?
plenty of old fords and massey ferguson in the mid 50's an up to be had at affordable prices..
/ Tractor for 4 acre farm #10
Dont forget the old deeres. You could get something like a 1010 or 2010 for much less then a kubota, and it could do a lot more.
/ Tractor for 4 acre farm #12
A good fit tractor (speaking of Deeres here) would be the 670, 770, 790 (all gear transmissions), 755, 855, 4100, 4110, 4115...those are all older machines and the prices should be $4K up to about $12K.
/ Tractor for 4 acre farm #13
Insufficient data. Especially since your profile doesn't contain regional information.
Where is the property located?
Does it have a house or barn on it?
Will you be living there?
Is it hilly or level, rocky, swampy, wooded, clear, open field?
Short paved drive or long dirt?
Do you want to use it for pasture, haying, row crops, orchard, forestry, aquaculture?
Even Joseph couldn't interpret Pharaoh's dreams until he told them to him.
/ Tractor for 4 acre farm #14
.. and eat a hole in your pants for parts and manitenance cost and purchase price.
hard to get the same options and hp at the low price of an old ford / fergy / massey fergy..
soundguy
/ Tractor for 4 acre farm #15
Roy's suggestions are good. And JD 2210, 2305, and the rest in this series. Also, older botas including BXs, 7000 series. Or any of the smaller CUT/SubCuts from Ford, NH, MF, Mahindra, Kioti, TYM would work just as well.
Best for just mowing/cart pulling/Snow: JD 400 series ($2K - $5K) used.
/ Tractor for 4 acre farm #16
Another post requests more info - that would be very helpful. The tractor size and capabilities is directly related to how long a project will take. You mentioned mowing so lets go there.
A tractor with a 60 inch mower traveling at 3.5 mph can mow 4 acres in 2 hours. Assume that this will not hold true on the first couple of mowings for various reasons, but later when you are accustomed to the tractor and have the high grass under control this will apply. Consult the following site to size your tractor and mower to fit the time you want to spend mowing. A Craftsman will take over 4 hours if it will even make the first pass.
TractorData.com - Mowing with tractors
Consider a front end loader. Think of a FEL as 4 guys that can lift 200 lbs each at your beck and call. If you are a senior like I am you will quickly appreciate the abilities of an FEL. Four guys cannot move as much dirt as quickly as I can with my FEL.
Consider NEW for this reason. I recently acquired a B3200 (18K) on my signature. No money down, 0% interest for 60 months and $300 per month. The tractor has a warranty and I can buy an extended warranty anytime before the 1st year is up. My 5 year old B7510 has never failed to start.
If you have limited time to work on the farm my suggestion is buy a little larger than what you really think you need and buy something reliable. You don't want to spend half your time repairing before you can get to work. If you are a mechanic you may be ok with that. I prefer to get work done.
If you are going to farm, garden, clear land or go into a building project there are several implements that can help you do those jobs.
List your projects for more detailed advice.
/ Tractor for 4 acre farm #17
How much of your property are you going to mow? I keep about 1.5 acres mowed and use a ride on, keeps my 135 free for other work on the property.
/ Tractor for 4 acre farm #18
I think you would be best fit with a 1 series JD tractor. Like the 1026r. Great little machine. Have no experience with them or the Kubota B (the comparable) but they are supposed to have some better features like operator comfort, 3PH control, lights and the best feature of the quick connect mid mount mower. A 2000 series Deere will do above and beyond what you need - buts it always good to get more than what you need:thumbsup:
BTW, a fel (front end loader) is a must for any tractor.
/ Tractor for 4 acre farm #19
My advice is a little different from everyone else as in foresight this is how I would do it now. Buy the biggest baddest tractor out there with the largest implements you can find. You soon figure out you need more land. Easier to convince the other half to get more land bigger house than vice versa good luck
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
