Kubota b2920 toolbox mounting?
/ Kubota b2920 toolbox mounting? #1
Watercarving
Kubota b2920
Can't seem to find a place to do this. Is there a good place to mount a toolbox/chain box on a b-series?
/ Kubota b2920 toolbox mounting? #3
I have a 2920 with a Sims cab, which enables you mount an open tray toolbox directly behind the seat. Very handy for the most commonly used tools and parts. In Vermont, that'd be shear pins :) I also mounted an enclosed toolbox under the seat for other less needed items.
/ Kubota b2920 toolbox mounting? #4
I don't mean to hijack the thread, but do you have a picture of that you could post? I also have a Sims cab on my B2620 and would like to see what you did. Thanks!
/ Kubota b2920 toolbox mounting? #5
On my B3200HSD, the toolbox is installed on the lower lefthand side of the ROPS...primarily because the backhoe I added required a swivel seat. The swivel seat mechanism didn't allow for the toolbox to be installed under the seat.
I've got a small one under the set. Wanted something larger. Maybe hold a chain.
/ Kubota b2920 toolbox mounting? #7
If you have a grill guard do you have room to weld a plate off of it and bolt down a box maybe. Paint it up nice and away you go!
/ Kubota b2920 toolbox mounting? #8
2018 DOOSAN G25WD0-T4F PORTABLE GENERATOR (A64281)
2018 DOOSAN...
2017 Volkswagon CC Sport Sedan (A61574)
2017 Volkswagon CC...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
COMBINATION ELECTRICAL & COOLING SYSTEM (A64281)
COMBINATION...
(2) 3.5" X 36" HYD CYLINDERS (A64280)
(2) 3.5" X 36" HYD...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
