Deere Generator 30 amp
   / Deere Generator 30 amp #1
KB9UDE
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
I am supposed to wire up a generator cord for a friend this week. The 30A 240v plug in this pic doesnt look like my twistlock L14 30. The best I can tell it may be a L17 30 receptacle?? Does anyone know for sure so I can be prepared??
Thanks!
   / Deere Generator 30 amp #2
The one on the right is a L5-30P 125 volt-30 amp.
The one on the left I don't have the package to but I do have 2 of them.
Home Depot should have all of them. Does that genny have sine-wave power?
Here is the manual link for a 8010 generator.
http://www.deere.com/en_US/docs/agr...009_AC-G6010H-HE-S-SE_G7510H-HE_G8010S-SE.pdf
The 120/240v looks like a 20A but specs say it should be a 30A 240V
CONTROL PANEL :
The generators are equipped with the following items:
- Idle Control Switch
- Hour Meter
- Volt Meter
- Circuit Breakers
- Two 125 Volt, 20 Amp, Duplex (2outlets), GFCI protected receptacles.
- One 125 Volt, 30 Amp, Locking Type Receptacle.
- One 125/250 Volt, 20 Amp, Locking Type Receptacle (AC-G6010).
- One 125/250 Volt, 30 Amp, Locking Type Receptacle (AC-G7510, AC-G8010).
I don't know for sure. I am setting up for a friend. I have never seen the unit in person. I will go to the dealer in the morning to check one out.
   / Deere Generator 30 amp #5
   / Deere Generator 30 amp #6
That won't be a sine-wave generator. Receptacle on the left is a 125 volt 30 amp (NEMA L5-30). Receptacle on the right is a 125/250 volt 20 amp (NEMA L14-20). I don't see a 125/250V 30A receptacle on the generator pictured. Strange for an 8000 Watt generator, but who knows were "John Deere" is having these made. Good Luck.
   / Deere Generator 30 amp #7
Sure looks like an L14-20R (20A) to me. I would have thought it would have been a L14-30R(30A). Notice that the ground tab(the one with a bend on it) is turned out on the L14-20R and it is turned in on the L14-30R.
I thought it should be a 14 30 also but it does appear to be a 20. I will stop by a dealer today and check it out.
   / Deere Generator 30 amp #9
I disagree.
All mechanically-coupled, direct engine-driven alternator heads produce a true sine wave AC output waveform. In fact, it would be tough to design such a direct driven alternator head to produce anything else. It appears the OP's generator is a mechanically-coupled direct engine driven alternator.
In contrast, all indirectly-coupled inverter-type generator sets must synthesize the output AC waveform from an input DC voltage (typically 12Vdc or 24Vdc). There are many approaches to doing so, with the results varying from simple step function voltage output to staircase output to true sine wave output, in order of increasing complexity and cost.
n.b.
The primary advantage of an indirectly-coupled inverter-type generator set is that the engine RPM is disassociated from the output frequency.
With a mechanically-coupled, direct engine-driven alternator, the attached engine must rotate at either 1800RPM (4 pole wound alternator) or 3600RPM (2 pole wound alternator) to maintain a 60Hz output. If the engine slows down, the output voltage and frequency both decrease.
With an indirectly-coupled inverter-type generator set, the attached engine powers an intermediate alternator; the AC output of that alternator is rectified (converted to DC) and is then used as the input to the inverter section -- which synthesizes a nominal 120Vac 60Hz waveform. The engine RPM can now be varied as needed against the power being drawn by the load; it is not necessary for the engine to run at a specific RPM. The result of this ability to vary speed as a function of load power leads to reductions in acoustic noise and fuel consumption.
The mechanically-coupled, direct engine-driven generator does have one significant performance benefit over it's inverter counterpart: it is superior in terms of handling motor starting and other high inrush current loads. This is due to the fact that there is far more rotating inertia in a mechanically-coupled, direct engine-driven generator.
Wrooster
   / Deere Generator 30 amp #10
Thanks!
Older thread I know :
http://www.tractorbynet.com/forums/rural-living/229995-deere-generator-30-amp.html
Howdy ! Hope all well. I have AC-G8010S-E JD generator. Saw where you wired plug for friend for this model. Recently bought brand new one , same model except has electric start also. Haven't had time to play with mine. I was wondering if you or anyone had any comments good/bad or ugly regarding this unit ? Or if You know friend still has it and or how its performed ?
Got mine at 50 % off regular price felt like I couldn't pass on it when I 'am in future need of a genny.
Thanks in advance !
Boone
71054 (A49346)
71054 (A49346)
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
Vacuworx MC3B Vacuum Lifter (A50860)
Vacuworx MC3B...
1273 (A50490)
1273 (A50490)
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
UNUSED 48 in. Oversized Bolt Cutters (A50860)
UNUSED 48 in...
