GR2110 Deck Drift
/ GR2110 Deck Drift #1
bergenfelter
Member
Edwards, IL
Kubota GR2110
I just took delivery on a new GR2110. One thing I have noticed is that if I raise the deck to the full up position, even with the engine left running, the deck drifts to the full down position after 5-10 minutes. Is this normal? Something that can be adjusted? Any help appreciated. Thanks.
/ GR2110 Deck Drift #3
Not normal.Mine will stay up for amonth and not leak down.Time to try out the Warranty :)
/ GR2110 Deck Drift
Thanks - Already have an email into the dealer. Do you use a snow thrower with yours? I also purchased the GR2707 two stage...
/ GR2110 Deck Drift #5
While it is not the same machine, when I first took delivery of the G2160 , it also dropped fairly quickly. Only thing I could figure out is that it may of had air in the system as with time it slowed down. The cylinder is only single acting with pressure coming from the charge pump for the deck lift with gravity down and there was not a easy way to bleed the cylinder out.
Only thing I can say is if it keeps on doing it have the dealer look at it but the G2160 still does bleed down overnight.
David Kb7uns
/ GR2110 Deck Drift #6
No blower-can't justify the cost with no more snow than we usually get in this area.I hear it's a really nice blower,though.
/ GR2110 Deck Drift
The dealer showed up today to pick it up and see what is up - definitely not normal. I put about 5 hours on it over the weekend thinking there was perhaps air in the system - no dice. We'll see what they find.
/ GR2110 Deck Drift
Update - Called dealer today for an update, said their service manager was out, my sales rep was out, was supposed to get an update today from my sales rep and they would "try" and get it back to me by the weekend.
The person at the dealer did some checking came back and said "well our service manager looked at it, made sure the linkage was adjusted OK and called Kubota to see what to do. They are waiting on Kubota to call back, but that will not be until next week. We are really sorry that you are having problems with your new tractor"
Took three days to do this? This is my first time purchase of a "high end" garden tractor. Last time I bought a tractor was a Craftsman 20.5HP in 1998 for $2K and ran flawlessly right out of the box for 12 years. So I have an empty garage stall where my shiny new Kubota used to sit and my wallet is many thousands lighter.
Give me some help here guys, more bugs to work out on these units? I am not a real happy new Kubota owner right now.
/ GR2110 Deck Drift #9
Suggest you research (search) the GR2110 on this site. After - You might want to give it back to Kubota and look at one of their BX models. I did and have been extremely happy ever since.
/ GR2110 Deck Drift
How do I "give" it back to Kubota - do they have some sort of 30 day satisfaction guarantee?
Thanks for the input.
/ GR2110 Deck Drift #11
Can't say if they do or don't. My dealer recognized quickly that I was not a happy camper and offered to do whatever it took to make things right. He took back the GR2110, Kubota refunded all payments and he gave me a great deal on a fully dressed out BX2660. In my book, the BX series tractor is far superior both in structure and versatility. Even my wife recognizes the BX as the better choice and loves using it.
/ GR2110 Deck Drift #12
I did exactly the same thing. Only I got $500 less then I paid for it after a year of problems and he knock $1,000 off the BX2660. So far a happy camper.:thumbsup:
/ GR2110 Deck Drift
Called the GM on Friday afternoon and gave him an earfull - we will see what happens...
/ GR2110 Deck Drift
Well - got the tractor back from the dealer today - they said there was some teflon tape in the valve spool - now the deck will stay up for a week - no problem. However, I was unhappy with the dealer repairs, they left hydraulic fluid all over the pump and frame rail, big mess. She is home now - guess I should be happy.
/ GR2110 Deck Drift
Well - that was my thought at first. But rather than have them tear down the whole hydraulic system, risking further contamination - i figure in a few machine hours I will change the fluid, cart filter and pull the suction pipe screen. Still have two years on the warranty to work out the bugs - hopefully this was the last and only one. Plus they made a mess of the machine when they repaired it, fluid all over the place, deck mat not re-installed correctly...
/ GR2110 Deck Drift #17
Decades ago when I began repairing my own semi tractors all the service literature strongly stressed the importance of using liquid teflon thread sealant on air brake systems vs teflon tape to avoid pieces of tape coming loose and getting lodged in a valve causing malfunctions.Never a problem-hard to believe everyone doesn't use it.
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
2001 Mack RD688S T/A Galbreath Roll Off Truck (A61573)
2001 Mack RD688S...
Coats 90X-AH-L Tire Changer Machine (A61573)
Coats 90X-AH-L...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
(12) 10" UP TO 6' I-BEAMS (A64280)
(12) 10" UP TO 6'...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
