Box Scraper hauling logs
/ hauling logs #21
Definitely cut the logs to the lengths needed. I use chain around the tunnel of my BB, the blade is a safety that keeps me from getting too ambitious and prevents the front end from coming off the ground when I do.
Handling is key, not only for skidding but also for milling, especially if you plan to mill the logs yourself. I've found I'm comfortable hauling those size butts out one at a time (especially fresh cut white pine, very heavy) but the tops I can sometimes take two or three at a time so the job isn't as lengthy as you might think. The key is not to be in a rush, any time spent working in the woods is time well spent, and as many have said, safety above all else!
Good luck, stay safe and enjoy!
/ hauling logs #22
I've yanked around some logs that size, I use my 3 pt boom pole. Using the hook point closest to the tractor. I don't lift the end of the log much, just a couple of inches, so that it is dragging, but not plowing. You will tear up the ground pretty good. I go slow, and keep the bucket low. I don't want to be field pizza.
/ hauling logs #23
Make yourself a log arch! You'll want it a little bigger than mine, but they work great. ~~ grnspot
Didn't know what a log arch was but now that I see one it is along the lines of what I was thinking.
Ever seen a grasshopper? Used for moving lengths of pipe. Difference is it has a long arm on it about 12' and its placed near the center of the pipe (or log in this case) so its got all the load.
Grasshopper
you can clobber one together for cheap. go to a junk yard and get a couple front spindles from a car with wheels. one 20' length of 2"x4"x1/4" tube steel and some scraps of other steel plus some chain and you are in business. If you don't have a welder you should be able to find someone who does and could put it all together for you.
/ hauling logs #24
thanks all for the suggestions, images and comments...
I will re-read the posts... but here are a few notes.
I have "surveyed" the trees as best I could and at about 5' off the ground level the largest trees are 22 inches... so my initial 24" was for the butt end +/-.
Comments that the B3030 is a smaller tractor are obviously correct, I go to the dealer and look at some of the bigger machines and they do have more weight and steel than what I have, but I am fortunate to have what I have and so am attempting to not trash the machine.... that's why I posted.
The specs say the 3ph will lift 2139 pounds at the lift point and 1300 pounds 24 inches behind the lift point... so these logs at 16 ft. would be very close to maxing out the lift arms with the box blade option... there is better geometry with the log closer to the lift arm pivot points. I have an "old farm" with virtually no buildings left, just old foundations and 15 acres of field and 70 of woods. The pine will be cut to build a shop-barn of a modest size....mostly for sheathing... so YES I can cut the logs shorter... and likely it will be a necessity with my machine... maybe go to a 9 - 11ft log if it is needed.
I guess I am a bit concerned about chaining directly to the 3ph, with the likely shifting of the log pressure. Am I being penny wise and pound foolish with wear and tear on the hydraulics... hauling logs... or are these rear hydraulics VERY strong... seals etc. I am new to tractors with only about 100 hours in the seat since I bought the used tractor, and that was mostly bush hogging....
I hear you all when you say take it slow and you will know in the first 2-3 ft of hauling. Within limits it is reasonably powerful tractor, but beyond limits things happen fast. I will keep my hand on the pto lever for sure.
I will try to haul when the ground is frozen.
A reasonable concern for a new tractor owner. - You will not wear out your hydraulics. They will only do what they can do. There are pressure reliefs in your hydraulic system to protect it. I think the log will have less shock leverage if it moves when chained to the hitch than if chained out on the box blade. Being farther aways gives a longer lever arm.
You are thinking things thru which is good. Handleing 10' or 12' logs makes it a much more reasonable job. Figure what lengths you need and cut to that as said above by Mike476. There will be less waste and it will be easier on you and the miller. You will need to be able to estimate board feet in a log. I would use the International 1/4" log rule.
Another thing you might consider - and I dont know your woods or your plans for your woods so I am just throwing this out. But nothing says you have to use your biggest trees. You can actually improve the quality of you wood lot by taking out smaller, stunted, or ill-formed trees and leaving the nice big ones grow. It is like money in the bank. I would select a tree to cut based on how easy I can fell it in the open and get to it with my tractor.
/ hauling logs #25
Are you cutting timber for fire wood, or saw timber?
Army Grunt
/ hauling logs #26
In my expirience dragging logs through the dirt some of that dirt sticks to the log and then has a bad effect on the sharpness of my saw. Like it wont cut nuttin no more. I got an old retired manure spreader with a long box removed the beater and sold the apron chain for scrap. the old nurr spreader can hold alot of logs. they can stick way out the back no problem. Plus the low box is ideal. this one has nice steel sides and is very sturdy. Or if you have a old pickup truck and wide open spaces you can haul them crosswise on the box. Might wan to chain them down.
/ hauling logs #27
Back in the day I skidded logs one summer to haul to the sawmill. I had a pair of log tongs much like ice tongs. Sharp points on the end dug into the log as I lifted or moved forward.
Basically I could back up over the log, lower the 3 point and many times the tongs would catch without much ado. Occasionally had to get off the tractor.
Lift and drive forward. Keep your foot ready to clutch the tractor or get off the propel pedal at the first indication of front end going airborne. Weight in the front end loader will keep the front down and the wheels engaged with the ground for better traction. You will be surprised at what you can move.
/ hauling logs #28
<snip>
I backed up tight to the log, and picked up the end with the chain hooked to the top of the arm the top link hooked to. Once off the ground, I chained the log up close to the draw bar. That is the chain on the top link arm only lifted, and the chain on the draw bar pulled.
There was enough slack in the pulling chain that the log rode a few inches behind the draw bar so turning wasn't a problem. And yes, it was a little more time consuming to do hook ups and unhooks..........
<snip>
<snip>
Grasshopper
<snip>
Here's my hitch ala Wyobuckaroo & 300UGUY (sorry for the blurry image):
I'm working on modifying a $69 Harbor Freight quick hitch into a skidder. The boom pole works, but has it's limitations. It really needs an attachment point about where the two stays are welded for better lift strength and to get the weight closer to the rear axle to reduce front axle lifting. The stays interfere with the log and the bottom cross between the 3PH pins always seems to interfere with the chain to the drawbar.
Working in the woods yesterday I made a real mess dragging this one log. I've been waiting for a good, hard freeze, but it's not here yet. I really need to make a log arch - or grasshopper - thanks for that link, sparc.
/ hauling logs #29
I see what your up against and can write what I did. 1st off nothing worse then trying to mill logs that are full of dirt, sand, rocks. Tractor Supply has a "CountyLine® Carry All" that hooks to the 3pt hitch. I used my Jinma 254 to haul logs up to 12 foot long with this setup, key to doing it is make sure you have room and keep the load balanced. This worked quite well, I milled thousands of boardfeet this way. You'll have to learn what your machine is capable of handling. This setup works good for miiling because it keeps the weight close and the log out of the "mill dulling compounds". Your B3030 looks to be slightly bigger then my jinma was so you should be able to carry these logs {@9-11'} easily. The down side to this is the fact you'll need a path that is wider then the length of your log. You'll be carrying the log not dragging it. I also used a small strap once in awhile to help hold the load secure, this was not allways needed.
If you have to drag just remember dirt is a pain when it's milling time{not miller time:)}. I have refused to mill logs before because of the way the guy pulled them out through a swamp. He didn't want to wait for me to come get the logs, so he took it upon himself to pull the logs out. I took one look at the logs and said "well,..... clean them 1st before they go on my mill" He said "never mind I'll find someone else" long story short NO ONE else would even touch the logs, now he has a nice big pile of compost.
/ hauling logs #31
Skidding logs packs dirt in the bark. I load mine on a hay wagon running gear and pull them out. I've loaded 20' logs 18" dia at the butt on my running gear with a Kubota B21 backhoe with only 930 lbs of lift.
You may need a weight box to be able to pick the logs up as I know I needed the weight of the hoe on back to keep the rear tires on the ground. You need to have flat level ground to lift them. Keep the log near the ground until are right next to the trailer then lift it on to the trailer keeping your hand on the bucket control so you can drop it fast if it starts to tip.
Here I am picking a 20' spruce with the B21
A load of logs hauled back in through the mud but the logs are clean.
Billy
/ hauling logs #32
I like the logging arch idea 'cus I made one (not long enough - would prefer it to be 8' long) see the photo.
I've skidded the size log your talking about and much longer with this rig because my woods are too rough to get the tractor into.
With an 8' tongue you could lift the log in the middle (more or less) and chain the butt to the tongue resulting in having the entire log off the ground.
Because mine's short, I just lift the butt, drag the tree to the work area, roll it over and clean off the end that dragged.
/ hauling logs #33
In post #28 Baby Grand shows about what I am using.
Only the lift arm I'm using off the top link part of the hitch is only about 1' long.
Works well.
Good luck
/ hauling logs #34
This is what I use for poles I don't want in the dirt, just make sure you can stop it when needed!
/ hauling logs #35
I used a log frame for a few years until I could get a winch, the frame is designed to do the same thing the winch does (sans the winch part). It cost me about $50 in steel and a few pounds of MIG wire. 4 hooks for chokers at the top of the frame, and steel mesh to keep the log from visiting the back of the tractor.
Sean
/ hauling logs #37
What size are those rears - are they on the sock rims? Wouldn't mind having wider rears on mine...
/ hauling logs
Many thanks to all who posted...
You offered experience and perspective from Nova Scotia to Texas.
I will move forward with more confidence and more humility.
Somehow this planning for hauling logs is a bit like when I recently took on sanding and scraping and painting my house... I gather up all these tools, set up the staging... and in about 5 minutes of work... half of the tools I figured I would need I realize are probably not necessary. I tried grinder this and that... I realize over and over again that traditional ways... like a scraper and disc sander... get the job done. I have read variations in several traditional ways of hauling logs and for that I am very grateful. I will guess that any half baked ideas will be seen in the woods as half baked after about 5 minutes. If I can I will try to use a log arch, as I can pull from the tow bar and keep a bunch of the "swamp" and "mud" off the logs. My take home is work slowly, enjoy the work in the woods, above all stay safe and respect the fact that logs are very heavy. I believe in stone work there is a phrase in Maine called the "granite kiss"... this is when a heavy stone pinches the fingers. I will do my best to avoid the "white pine kiss" Cheers. A Happy New Year to all.
/ hauling logs #39
Easygo's idea is probably the most economical.
The photo shows a rig that I made that goes a step further. I bought a 3 Pt drawbar from Tractor Supply, a Drawbar Stabilizer from Northern Tool, some flat bar, and a pair of grab hooks from a hardware store. I have mostly used it for waste logs that were smaller than the one hooked up in the photo. If I were to haul anything bigger, I would be sure to carry low, and to have it hitched such that the drawbar would stop it from coming forward.
Another benefit to the Drawbar Stabilizer is that it includes a 2" receiver. I put a ball mount into it when I want to move my utility trailer around with the tractor.
I bought my used tractor with a backhoe on it. I got the 3PT arms and all except the top link (which I replaced from Tractor Supply). However, I did not get the original low drawbar. I may see If I can get one made someday.
Go carefully, and you should be safe.
/ hauling logs #40
Just thinking out loud here.
A quick hitch could be used to lift, secure and control the butt end of a log. Cat 1 QH is 27" wide so your logs would fit nicely.
Then place a two or four wheeled fat tire dolly toward the middle of the log. Probably would have to be secured with chain and binder. Then tow away.
Hmmm. Maybe one of those half baked ideas.
2016 CATERPILLAR 926M WHEEL LOADER (A65053)
2016 CATERPILLAR...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
