Jima Y385T powered Mazda Pickup
/ Jima Y385T powered Mazda Pickup
I bought it on Ebay about 2 years ago. There was a guy that was importing them from India or China and he had a storage of them in Portland Oregon (about 60 miles from my home). They are really hard to get now, I guess because they are not EPA rated. I have read that running on bio-diesel the engines exceed EPA standards, but I have not found any more for sale in the Portland area. The engine is a blast to start, (hand crank) and just ticks along at 450 RPM. It sounds like an old grandfather clock, very relaxing to watch, with the open rocker arms and pushrods going up and down. I used a 2" wide cogbelt (timing belt) to drive the 5 KW Generator head.
/ Jima Y385T powered Mazda Pickup #102
Cool, I have been building a 6/1, 5KW genset in my garage since December, and it is just about ready for installation in the generator shed. Mine is just for backup but I am employing a heatexchanger to recover the cooling system heat into my domestic hot water. About the only thing I will be missing in a power outtage will be the oven and the electric dryer:) It's miserly fuel consumption also means the fuel stored will go much further.
Thanks for posting the stress test info on the diesel truck engine. Good to see it appears to be surviving the installation.
I have been asked several times how the flywheel was balanced. I wanted to post pictures of the process but did not take any pictures when I did it (I was having too much fun) so I guess I will just have to describe it.
It is based on the fact that two rods at 90 degree angles to each other (one on top of the other) have very, very little contact area and thus very low rolling resistance, allowing for very fine static balancing.
How it was done:
During the machining of the flywheel, while it was still in the lathe, the center hole of the flywheel was set up to within .0001 of the crankshaft bore. This allowed the center hole of the flywheel to be used as true dead center.
I then machined a shaft 8" long with a .0015 taper from one end to the other and sized it so that it would be a slight press fit when inserted into the flywheel center hole. So, I now have a fly wheel with a shaft sticking through the center of it (shaft is sticking out of both sides)
Next: I placed two pcs of 3/4" Thompson Rod (62 Rockwell C scale -case hardened,) on steel risers about 6" apart from each other that alllowed the flywheel and shaft to be set on them and rotate until the heavy side was on the bottom. Using a machinist level I adjusted the two pcs of Thompson rod until they were level with each other.
Then:
I placed the flywheel and shaft on the Thompson Rods and allowed the flywheel to rotate until the heavy point was down. I then made a hanging wire pointer out of brass wire that hung from the tapered flywheel shaft. The wires point, pointed to the place on the flywheel that I was to drill a 1/2" diameter hole in the flywheel to remove material.
This process was repeated 8 or 10 times until the flywheel no longer rotated when placed on the two pcs of Thompson rod. In fact at the end of the process I could get the flywheel to rotate either direction just by blowing on it. I say it was within a quarter of an ounce, but in fact it was probably much closer than that.
This is the simple explaination of how it worked, there is much more to it.
The surface finish of the rods are important, the taper of the flywheel shaft is important, accurate machining and good dial / digital indicators can affect the results. I used Thompson Rods because they are very hard and have a good surface finish, I used Steel as the flywheel shaft and polished it before I used it.
How did I know how deep to drill the holes in the flywheel?
I machined a 1/2" diameter shaft of cast iron and made various lenghts of them. I would attach them to the top of the flywheel at the pitch diameter that the hole would be drilled. The length of these shafts would then be the depth of the hole that would be drilled into the flywheel.
I did one hole at a time, because as I would drill each hole location of the next 'heavy spot' would change.
It ended up with five 1/2" holes drilled into the flywheel. hole number five was only about 3/4 of an inch deep. It took 3 or 4 shots at the final hole (each one just a fraction deeper) before the flywheel no longer moved when supported between the Thompson Rods.
This was a modification of what an old journeyman machinist taught me when I was serving my apprenticeship. We used to have to balance our grinding wheels on our surface grinder before using them so that the wheel balance would not leave marks on the tools and dies we were building.
I hope this helps explain what I did. I wish now that I had taken pictures. It sure worked out well...there is no flywheel vibration at all engine speeds.
Thanks,
-Dan-
Correction:
I ended up with seven balancing holes in the flywheel when it was done. (After two years I just about forgot) The whole process took about 4 hours, but time went by real quick (it was a real, real fun to balance the flywheel!!!!)
Thanks,
-Dan-
/ Jima Y385T powered Mazda Pickup #105
I dynamically balancd mine. Removed the head and crankcase door and spun the crank, flywheels, piston and rod up as close as I could get to the 650 RPM running speed and adjusted counterweights on the wheels untill the movement of the frame was at a minimum(under .005" for-aft) the whole assembly, engine, generator and frame were up on 3/4" pipe rollers and I could easilly move the 1000# of weight with the tip of a finger. I re-assembed the engine after balance and while it was still on the rollers, ran it with 2KW of electrical load on the generator. For-aft movement was about .010"-.015". It will be bolted to a 1300# block of concrete, but it runs happily under 3KW load just setting on my garage floor.
/ Jima Y385T powered Mazda Pickup #107
Soundguy said:
Nice setup.. Where did you find the engine?
Soundguy
I've been debating trying to find an old unit out of a refrigerated trailer, might be able to find a salvageable engine there, but don't know what it would cost.
I found the engine brand new on Ebay. It came from Coldwater Tractors in Washington State. I paid about $900 -$950 for it.
/ Jima Y385T powered Mazda Pickup #109
Hi Dan,
Nice and creative project!
I had to register to ask, if you have cancelled the idea of turbocharging your Y385T?
I wanted to find out if anyone has experience on this matter.
How is the engine holding up so far?
The word is, that a Jinma 254 here in Denmark reached approx. 7,000 hrs. before the engine was replaced. The engine was replaced due to a broken valve. The damage was "minor" but the owner chose to replace the entire engine, without knowing at the time what had caused the bad noise at start attempt.
I bougt my tractor at an auktion as "unused". I wasn't able to see it before I bought it, as I was at sea at the moment.
I got it cheap, though. When the tractor arrived, the engine oil was heavily contaminated with water. Initially I suspected a cylinder liner O-ring, as I did not know the engine is fitted with dry liners. It turned out, that the engine block was cracked on the way from China, due to none or too little anti-freeze.
I ordered a new engine (at least I thought), but recieved only an engine block. So what the h..., I replaced the block. The tractor has now been doing well for 45 hrs since then, but sometimes I miss the turbo whine, and a bit more power.
When the tractor was exploded, I dismantled all transmission and gear covers and flushed it all out with diesel oil. Amazing how much dirt, paint chips etc. I was left with.
//SC
Hello everyone,
It has been over a year since I have updated the Jinma Mazda pickup story. Yes, I still have the pickup and yes it is still running (quite well, I must say) I now have 40,000 miles on the engine and it is still running great. I have had no problems with it. This last summer I drove it to Lincoln City (on the oregon coast) with a small load of firewood (for a week of camping) and I still drive it most every week. I also took a heaping load of firewood to my parents house in it.
I have been very happy with the pickup and the Jinma (Yangdong) engine. The engine is getting a little dirty (I have not cleaned it since it was installed) and it drips a little oil in the garage, but it seems to run a little better every month.
I took the starter out and oiled the bushings (it was starting to squeal) but other than that I just drive the crud out of it.
I will keep you informed of any big developments...
Thanks,
-Dan-
/ Jima Y385T powered Mazda Pickup #113
Dan:
glad to hear it is still plugging along! also good so see you back in here have not heard from you in long while. Wish I had the same abilities as you in the machining areas, I can buy some NEW CAT engines that are surplus from work 65HP $2800 bucks each brand new less than 1/2 the cost :D I think it would drop into the F150 pretty slick ;)
Mark
Hello everyone!
It had been close to two years since I have updated everyone on the Jinma Y385T powered Mazda Pickup.
Here is the update:
I have been running the truck a few times a month until this spring when I (again) blew a head gasket. This is the second time I have a blown a head gasket on the engine. This time it was real bad, engine coolent got into into the number 2 cylinder and hydo locked the engine. I pushed it into the barn - and there it sits.
I really doubt that I can use the stock Jinma head gaskets, they really do not seem to hold up.
I am thinking about using a solid copper head gasket and then adding head gasket leak liquid to help seal the little leaks.
If that does not work, then I am really running out of ideas of how to keep this little engine running without blowing head gaskets. The engine has been running great other than the head gaskets. I am really happy with the truck. The Y385T engine seems plenty tough, other than the head gaskets.
I have 45,000+ miles on it, it has proved it's worth a hundred times over, I have hauled tons of river rock, hay and dirt with the pickup. I have run the living crap out of that little engine, I can't believe it has run as far as it has.
Any thoughts?
I hate to leave this project with this head gasket problem, but I am running out of ideas.
Thanks,
-Dan-
/ Jima Y385T powered Mazda Pickup #115
Are the block and the head truly flat? Most of the time when an engine keeps blowing head gaskets it is because the head is warped or the block needs to be decked.
/ Jima Y385T powered Mazda Pickup #116
Here's something that's worth a try. Use property class 10.9 head studs (instead of bolts) with hardened washers and property class 10 nuts. Torque up in two stages (lubricate threads with anti sieze), first stage being 70% of the final torque. Increase the original torque setting by (edit: 5 ft. lbs.). Continue to use the OEM composition gasket. Cat and IH have used this fix before on similar problems. Make sure all mating surfaces are impeccably clean and coat both sides of the gasket with gasket shellac.
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/Permatex_Indian_Head_Gasket_Shellac_Compound.htm
Note: As Rich stated, make sure the deck and head are perfectly flat ± .0005".
DON'T USE ANY STOP LEAK OF ANY KIND!
/ Jima Y385T powered Mazda Pickup #117
Hi DAN:
I think BOB has a very good plan for the issue of the head gaskets, better studs and proper assembly torq after assured flatness.
If that does not work it may be the sustained high RPM (over rated RPM) is probably pretty hard on that little engine.
Soft Copper gasket would also work with proper thickness so as to not lighten up on the compression much. As far as lube on the gasket cast iron to cast iron should not be required as they heat at same rates and move same amount.
I'm not sure if they make a "better gasket" anywhere but I would think there are someone out there in China that has dealt with this issue already. BlueChip or Affordable should be able to find out as they both are great dealers with contacts over there..
Mark
/ Jima Y385T powered Mazda Pickup #118
Third vote on the head studs. That is how we keep the boosted toyota 22-RE engines alive and well...
/ Jima Y385T powered Mazda Pickup #119
I agree to make sure the head and block are flat then use the factory gasket and aftermarket studs. Many many of these motors are running around with these gaskets with no issues.
Chris
/ Jima Y385T powered Mazda Pickup #120
are there any aftermarket gasket options available?
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
VOLVO P7110 ASPHALT PAVER (A65053)
VOLVO P7110...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
