Engine Won't Turn Over
/ Engine Won't Turn Over #1
papa51
Mahindra 2816 4wd
Been working my 2816 regularly on my horse farm. Went out to start it this morning, turned the key on to let the glow plugs heat up, tried to start it and it just ground over a time or two and stopped. Hooked up the jumper cables and don't get a grunt. Checked the tractor battery and it's showing 12+ volts but no volts at solenoid. In fact, it shows a negative read out there. When I turn the key on there is a clicking sound behind the dash near the switch. Had a similar problem this summer and replaced the solenoid with a new one. Anybody know if there is a relay behind the dash that would be faulty?? Or any other ideas? Really need to get this thing running as I have a LOT of work I need to do.
Thanks,
C Slaughter:confused2:
/ Engine Won't Turn Over #2
Thanks,
I would check that all the connections are clean and tight. A fully charged battery should read about 13.5 volts. :thumbsup:
Thanks, Randall. I did that first thing. Even took the ground loose and removed the paint so it's metal to metal contact when I re-installed it. Battery posts are clean and tight, as are the contact nuts on the starter / solenoid. I also checked the safety switches on the pto and the gear shift. Guess I'll have to start at the positive cable and try to run it out connection by connection. Talked to a service man at a local dealer and he didn't understand why the dash lights won't come on when I hook it up to a running truck via jumper cables unless there is some sort of short or fuse issue. I'll try to check that in the morning.
Cliff S.
/ Engine Won't Turn Over #4
How old is the battery? It may be bad?
Even if the battery is bad shouldn't it have turned over when I hooked the jumper cables up to it, or at least the dash lights come on??
/ Engine Won't Turn Over #6
I'd say it's either the switch itself or a bad ground. Hook the positive jumper to the positive side of the battery and hook the negative side to the engine itself. I'm curious.
Will do, Dbellrn. I'm thinking the switch but I'll try the jumper cable hookup. I'm also going to take the battery and have it tested by a pro. All I have is a cheap meter that came from Auto Zone. It'll be Friday before I have a chance. I'll be on the road tomorrow. I'll post the results. Thanks for your input.
Cs
/ Engine Won't Turn Over #8
If you cleaned all cabels you might want to make sure all cabels are good. I had the same problem with my Kubota, it turned out the cabels were bad. Replaced them tractor fired right up. Jim
Great advice, Jim. I just came in from my morning feeding and pulling the battery to have it checked by a professional. I noticed the ground cable does indeed look suspicious so I'm also planning on replacing it. I guess I might as well go ahead and get the positive one while I'm at the dealership. As you know, there are few things more aggravating than needing your tractor and it not start. I might go ahead and pull the switch and have it checked for continuity also. I'll post whatever I found was the problem. Thanks, again.
/ Engine Won't Turn Over #10
My money is on a bad battery......:thumbsup:
/ Engine Won't Turn Over #11
A bad battery can force current to ground. not sure why this happens, but i have seen it happen in 2 separate instances. Once on an older ford bronco. Everyone was sure that the ground wires or the positive wires were bad. when we tried to jump it sometimes we'd even see some smoke.
All the dash lights would fade out .. no start.
Finally took the old battery out and popped in one from another rig, and the truck started right up.
The second one was on my old JD870 tractor. I was sure it was the fuse or the cables again. Messed about for a day, charging battery, etc. Nothing.
Jumping also didnt help. I have a feeling a bad battery just robs all the jumping batteries amperage.. but i have no proof of this happening. All i know is i put in a new battery, and it fired up just fine.
Had battery checked at local service center and it's fine. I've got it on a slow overnight charge since it's already out. I'm going to start at the battery and work forward tomorrow. I'm now thinking it might be the ground cable. It sure seems to be small gauge wire for a ground connection and does show some signs of excess heat at the clamp. I'm going to go down a gauge or two and replace the clamp, just to be safe. I'll post my findings.
Thanks
/ Engine Won't Turn Over #13
Papa, once you get all the cables hooked back up to the battery, take a volt meter and put the positive test lead on the negative post of the battery then put the negative test lead on an exposed portion of metal on the engine block. This is called a voltage drop test. Ideally it should read next to nothing. If you have a bad ground it will show up to and including battery voltage. The current is flowing through the meter instead of the cable.
Great tip, Dbellrn. I'll put this in my catalog of "things to try" for future use!!!
Problem solved. Dbellrn was dead-on with the ground issue. At some point, a limb or broken sapling had wedged it's way between the ground wire and frame connection. I noticed this the first day and removed it. However, what I didn't know, and what could have been detected with a tug or two, the limb had pulled the ground cable enough to loosen it in the frame connector. While it hadn't been pulled completely free, it had been pulled enough to compromise the connection.
Thanks to everyone who offered advice, but especially to Dbellrn.
NOTE: I tried voltage drop test after I had corrected the problem and got a very minimal readout, next to nothing. You can bet I'll remember this tip!! Thanks
/ Engine Won't Turn Over #16
glad you got it fixed...but im confused, in your 2nd post you said all ground wires were removed and re-tightened.??
oh well, glad all is now working good:thumbsup:
Allow me to clarify, grsthegreat, initially I removed the clamps from the battery terminal, cleaned and re-tightened. Then I removed the ground from the frame and cleaned the frame of paint. I SHOULD have checked the wire to connector fit and I would have found it was not tight. Apparently the offending limb had put just enough force on the cable to loosen it inside the connector to the point the connection wasn't sufficient to complete the ground but not loose enough to be noticeable to the eye.
Thanks for your help and sorry for the confusion.
/ Engine Won't Turn Over #18
ohhh, ok i see what you mean now.
again, glad all is well in the world again for your tractor
/ Engine Won't Turn Over #19
Glad I could help Papa. Ground problems can create a variety of symptoms. Go have fun on your tractor!
Tennant M30 (A64127)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
