Securing hydraulic Top Link
/ Securing hydraulic Top Link #1
boomer632
Steeler Country
2011 LS R4041EZ - 2014 Bad Boy CZT Elite - 1948 Ford 8N
What do you guys do with your hydraulic top link when you have nothing attached to 3pt? Looking for some ideas that dont involve removing the top link. There is a hook on the tractor now that I use to hold the top link up and out of the way. Obviously, the hook wont fit a 2" hydraulic cylinder..
/ Securing hydraulic Top Link #2
I have a quick hitch that never comes off, so I don't have that problem.
I guess you will have to customize the hook, or just take the HTL off for longer periods with nothing on the 3 pt.
JB
/ Securing hydraulic Top Link #3
I use a heavy wire from a clothes dryer that I use to wrap around a cross tube. I've also bent the hook out a bit so it would hold the toplink **temporarily**... since it isn't long enough to hold it tight while you are driving around.
/ Securing hydraulic Top Link #4
I have one of the adj. rubber straps (bungee) - the kind that has the holes punched in it for hooks the entire length and not just one the end. Used my factory "top link hook", put the first hole in the adj on the hook, then around the hydro cal, then pick a nice tight fitting hole in the adj. area of the bungee and slipped it over the hook. Basically just a loop of rubber from my factory hook around the cyl. and back. Keeps it from bouncing around and holds it good and tight.
The bungee is sold at Home Depot for about $4
Good luck
/ Securing hydraulic Top Link #5
I was able to modify both of my OEM top link holders to work. On the red tractor all that I did was twist the hook 90* and it hooks perfectly on the hydraulic port. On the blue tractor all I did was heat up and widen the hook to accept the 3" cylinder.
/ Securing hydraulic Top Link #6
This is how I did it. This was made as a temp, but has worked so good I never changed it.
/ Securing hydraulic Top Link #7
:eek::eek::eek: For the few times I need to tie it up... this works for me.
/ Securing hydraulic Top Link #8
Boomer, I think that you might be able to just twist your OEM hook retainer 90* and hook on to the hydraulic port as I have done on my red tractor.
One of those things of you won't know for sure until you have it on the tractor.
/ Securing hydraulic Top Link #9
I have a light chain for the few times mine isn't used and have some 3/16 rod to make my own but amfter reading about the bungee I will probably look at that. The steel hook might catch on something.
/ Securing hydraulic Top Link #10
Does the OEM hook catch on anything? Not that a flexible strap does not work, it does and will. When you have the top link hooked with a hook like the OEM hooks, the cylinder does not move. I have had zero problems with either tractor going on 7 years with the blue tractor. About 800 hours of use between the 2.
2000 Ford F-450 Dump Truck (Diesel), VIN # 1FDXW46F5YEB20130 (A61165)
2000 Ford F-450...
2025 Wolverine CB-11-750F Hydraulic Concrete Breaker Skid Steer Attachment (A60353)
2025 Wolverine...
LandHonor LHR-G209 Anchor Shackle Set (A60352)
LandHonor LHR-G209...
LandHonor LHR-MS0810 Galvanized Apex Roof Metal Shed (A60352)
LandHonor...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 X39 Hydraulic...
2019 GENIE S-60XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC...
