split point drill bits
/ split point drill bits #1
deereman75
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well I just got a set of milwaukee thunderbit split points, and I am wondering how I could sharpen them when they get dull. I cant seem to figure out if/how you can hand sharpen them, and I will not buy a drill doctor. Can I sharpen them any way? Or will I have to send them out?
/ split point drill bits #3
Shield Arc, which part of the grinding wheel do you use to sharpen. I was taught to use the side of the wheel.
When ever I come across a split point bit I just sharpen them like any other bit.
I found this video on Youtube, pretty close to how I sharpen a bit.
How to sharpen a 118* drill bit - YouTube
This looks interesting.
Hand Held Drill Bit Sharpner - YouTube
Ok thanks. I will have to get a new wheel for my grinder though, this one seems to be warped, it wobbles side to side. (Might also be the el cheepo bench grinder) If it is the grinder, I will just set up my 70 year old v-belt driven grinder, and use it. Hopefully these milwaukee black oxide thunderbits will go for a while before I need to sharpen them.
/ split point drill bits #5
I was taught to never use the side of the wheel, and the company I worked for the safety department would have a fit if they caught you using the side of the wheel. So I use the face. Few years ago I bought a green wheel for my bench grinder, I was going to use it for tungsten but I liked it better for drill bits.
/ split point drill bits #6
Never use the side of a grinding wheel! They may come apart. The Green wheel is designed for carbide but works well on most hard surfaces. It will break down quickly and needs frequent dressing. I prefer a hard white wheel to dress tools.
Russell
/ split point drill bits #7
Russell
And if a third to confirm what they said is needed, NEVER use the side of a grinding wheel. The WILL explode on you! If the surface isn't smooth, dress it with an appropriate tool.
David from jax
/ split point drill bits #8
You need to keep a good flat wheel on your grinder just for drill bits and I keep the other wheel for HSS lathe tools. Have a good light on your grinder and a water cup. Leep a cool tool while grinding and drilling. Do not turn the bit blue while grinding. Once blue you have ruined the temper of the steel. Blue chips out of your work are not good either. My Dad couldn't figure out why I got upset when he used my tool grinder for cleaning up a part after cutting with a torch.
DanD
/ split point drill bits #9
DanD
cleaning up welds are what right angle grinders are made for...though I would have had to explain to "Dad" a time or two before I got upset with him. Spare grinding wheels are too cheap to take the chance on offending Dad.
David from jax
/ split point drill bits #11
Get yourself a Drill Doctor It will split a point very well If you only use up to 1/2 " the 500 model If you go to 3/4" Go with the 750
The drill doctor 500x would work, but it costs $100. There are a lot of things I would rather spend $100 on. And since I only have one 14 piece set of split points, and a ton of normal 118 deg bit sets (which can easily be sharpened on a grinder), a drill doctor just isnt worth it for one set. I would rather spend my $100 to get my belt drive grinder set up with new wheels, and re wired, and build a stand for it.
/ split point drill bits #13
OK but it will split point a regular bit any size
/ split point drill bits #15
It took me a long time before buying the DD. A lot of money to do something that a bench grinder can do. It finally came down to a project where I had to drill out a bunch of rivets (couldn't use a torch). I got sick and tired of having to stop and walk back to the grinder to sharpen the bits.
/ split point drill bits #16
Like Shield Arc , Was taught at a very young age by my grandfather to "NOT" sharpen anything on the side of a grinding wheel . Only took a couple of " Gibbs " slaps ( from NCIS show ) to the back of the head to have that sink in .:thumbsup:
Speaking of old belt drive grinders , think my grandfathers is still mounted to the workbench of my Dad's second garage , have to check on that .
Still though , With all of us being taught NOT to do that , wonder if something has changed , or is the guy in the video link shield arc posted a few cans short of a 6 pack ?
Fred H.
/ split point drill bits #17
Fred H.
Fred H.
I just watched the video, and the guy is using the face of the wheel, after he used a dressor on it to make it smooth. He is doing it the same way I do it. I think the next poster
"Orezok" is the one that posted saying he was taught to use the side of the wheel, which is not the way the video shows, and a more dangerous way.
I know a lot of people that use the side of the wheel for grinding, because it is more convientant than having to dress the face of the wheel, but the only reason the face is not as flat as the side, is because it was used. If you use the side of the wheel and it becomes "grooved or worn", it is almost impossible to dress it back flat without becoming a safety problem (I would think, anyway...). Makes the wheel thin and just plane unsafe looking. The only people who would get away with using the side of the grinding wheel would be in shops (home or otherwise) that do not do very much grinding or sharpening in the big scheme of things. A shop that regularly sharpens drill bits will run into problems using the side of the wheel in a hurry.
David from jax
/ split point drill bits #18
Man there is so much I just don't know. Thanks guys
Yeah, I felt the same way the last time I went to make a movie...
We each have our strengths and weakness in our lives. Don't sell yourself short, just join in and ask somebody who knows a little bit about what you don't know and then you will be smarter about it.
I don't own a drill doctor, and usually don't "drill" holes because I prefer to drill them with my milling machine, so I typically use two flute endmills, or center cutting multi flutes, which I have a rather large assortment. The drills I do use, are mostly for holes that are done by a hand held power drill. Those typically get broken long before they wear out, lol.
David from jax
/ split point drill bits #19
What is used to dress the grinding wheel?
I have a belt driven unit mounted on a bench you straddle and sit on. It was my dad's and don't recall it being dressed. It was use mostly for axes. It has two wheels for grinding one is in the same plane as the belt and turns very fast and the other is 90 degrees from the first and runs slower.
I have been using the higher speed wheel for the axes. I seldom use the slow wheel, have used for knives. I notice the large wheel is out of round, blade bounces on the face.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2014 MAC FLAMELESS HEATER (A68842)
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
Unused 2021 HLA 20LA04504 Concrete Chute Bucket Skid Steer Attachment (A66734)
Unused 2021 HLA...
