Lely Optimo 240 lubrication
/ Lely Optimo 240 lubrication #1
shanehobson
New Zealand
Ford 3000 (x2), Kubota F1900, Kubota B2150HST, IH434, Same Minitauro 60, Zetor 6745 (x2)
Can anyone give me some pointers for lubricating my disc mower please ?
Does it use sealed bearings or an oil bath in the mower bar ?
Grease or gear oil ?
Any info would be appreciated as googling hasn't revealed anything helpful.
Hay season starts next week so I want to be sure all my gear is just right.
Thank you
Shane
/ Lely Optimo 240 lubrication #2
Shanehobson,
I am sorry I am unable to be of assistance. Our operation has a Lely tedder rake and it has grease fittings. Not familiar with your machine.
I about fell over when you stated you needed to start haying very shortly and not knowing where you are located we are in the second day of winter here in Oregon.
Checked out a couple of your old posts and noticed you are on the other side of the world. Understand the difference in haying seasons.
Wish I could help! Good luck in determining how to service your mower.
Nick, North West Farmer
/ Lely Optimo 240 lubrication #3
Thank you
Shane
I would think the bar had oil, but it looks like I am wrong. Never seen one of these mowers though, our disk mower uses trans hydraulic oil in the bar/gear case.
I did find this, it has lubes listed on the parts break downs. Page 11 lists 2 different ones.
http://www.triplehequipment.com/pdf/Lelypdf/mower/mowerpart/optimo_240c_parts.pdf
Here is another forum that it is discussed
Zetorworld forum: implement talk [Gear Box Oil/Grease]
Hope this helps
Thank you
/ Lely Optimo 240 lubrication #5
Thank you
Shane
The mower uses EP-0 grease.
Do not use gear oil in the Optimo series mowers. You can download a Shop manual here http://haytools.com/public_html/images/Lely_Manuals/Lely_Repair_Manual.pdf
The equivalent of 2 quarts would lubricate the whole mower if totally empty. Just top off the cutter heads. They take a total of 3.3 oz. The main gearbox has 2 compartments. Each compartment takes a pint. Make sure that each vent is free enough for you to blow through.
HayDR
UNUSED KJ K1522 PORTABLE RESTROOM (A62131)
UNUSED KJ K1522...
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
1995 CATERPILLAR 938F WHEEL LOADER (A62129)
1995 CATERPILLAR...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
