Harbor Freight Powder Coat Paint
   / Harbor Freight Powder Coat Paint #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
I am almost out of the powder coat I purchased a few years back from Eastwoods and noticed that Harbor freight has a few colors at $4.99 lb. Has anyone tried Harbor Freight's Powder Coat? If so how do you like it compared to other brands.
16 Oz. Powder Coat Paint, Red
Well yesterday I picked up a lb of Harbor Freight's powder coat in red, yellow, black and white. I give it a try and take a few pictures.
   / Harbor Freight Powder Coat Paint #3
How do you bake the paint after spraying it?
   / Harbor Freight Powder Coat Paint #4
Can these colors be mixed for a different shade?
I bake it in an old kitchen oven I have in my shop ay 350-400 degrees F for 10-12 minutes. I have used several brands of powder paint before with excellent results.
My neighbor built a large walk in oven to bake larger pieces.
I have blended other polyester powder coats before with good results but have not tried blending Harbor Freight's powder coat. BTW, Harbor Freight's powder coat is made in India.
   / Harbor Freight Powder Coat Paint #7
Thanks.
I picked up an HF Powder Coater at a yard sale recently ($10 - missing the scatter tips) and plan to use a yard sale toaster oven ($1) to bake the small items I will coat.
India - interesting.
Clem
   / Harbor Freight Powder Coat Paint #8
What type of element did your neighbor use to heat the walk-in oven?
   / Harbor Freight Powder Coat Paint #9
I would imagine the elements looked something like this to heat a walk in oven.
   / Harbor Freight Powder Coat Paint #10
i have used the white it smokes more than the other power that i use
Basically all it is a small insulated room with a few kitchen oven elements wired into the side walls. I am not totally sure how he controls the temperature.
Finally have a little time. I'll spray a few small scrap pieces with my air brush and see how the turn out. Pictures to follow. I has hoping the yellow would be close to an industrial yellow but instead it is somewhere between a yellow and pale orange.
Here a picture of Harbor Freight's powder coat. I applied it to a few old blades I had laying around. I did not want to spend the time setting up my electric powder coating gun so I applied it using a little air gun similar to a liquid air brush. I first heated up the metal using my propane torch then simply sprayed on the powder. When the powder coat hits the heated metal it instantly melts onto the part. I then baked them at 400 degrees for around 15 minutes.
As you can see the yellow, white and red turned pretty good while the flat black not so good. Later I'll paint a few larger pieces.
   / Harbor Freight Powder Coat Paint #13
Those look like ... lures.
Great thread - I had no idea powder coat could be a home brew operation and the results look very nice.
   / Harbor Freight Powder Coat Paint #15
What kind of surface prep do you need for powder coat? For rusty metal spray primer I just wire brush.
   / Harbor Freight Powder Coat Paint #16
i sand blast
On those blades, which are nickel plated steel, I only wiped them down with a paper towel. Prep for powder coating is basically the same as with all other paints. Poor or little prep and your paint may not adhere well.
Yep, those are old spinner blades I had laying around. I've been powder coating metal lures and brackets that I've made for quite some time now with really good results. For small parts you can heat the part then swish it in the powder, heat and spray the powder, or use a fluidizing bed. For larger parts I use a gun I purchased form Eastwoods.
What other powders have you used? I've used Eastwood's, Columbia Coating's, CPS and now Harbor Freight's.
   / Harbor Freight Powder Coat Paint #20
that is all i have used i have two others but the colors are plain have not found a use for then
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
60" HANG-ON WHEEL LOADER FORKS (A60429)
60" HANG-ON WHEEL...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
