Loader installing hooks on fel
/ installing hooks on fel #21
here is what I did:
http://www.tractorbynet.com/forums/customization/208653-so-you-think-converting-pin-4.html
if you go to post 34 of this thread you will see the top plate I welded on and the hooks welded on to that. The hooks on the side down lower are mainly for securing loads that would fall out of the bucket, like a big stump or something. The pulling hooks are in line with the loader arms to reduce torque. The hooks were purchased at Race Brothers in Harrison Ar. and were less than $6 each. Welding was done by me, and I ain't no real welder:)
James K0UA
k0ua said:
here is what I did:
James K0UA
This looks like what I had in mind. Low cost but effective.
/ installing hooks on fel #23
Here is another option that minimizes add-on weight.
/ installing hooks on fel #24
/ installing hooks on fel #25
yep that looks good too, but I needed top chunk of steel for 2 other reasons, One was to tie into the SSQA backplate I was welding on at the time to tie it all together and Two I have ideas of maybe putting a 2 inch reciever in the middle for other uses.
James K0UA
/ installing hooks on fel #26
One more option - My BX25 came with a dealer installed grab hook welded on top and in the middle of the bucket. I also wanted hooks towards the ends of the bucket. At about that time I was purchasing a set of BXpanded pallet forks which look like this. The brackets which hold the forks provide for numerous other uses. For less than $20 I made 2 hooks for the ends of the bucket as seen here by welding 2 grab hooks to 2"x2" square pieces of tubing and mounting them with the brackets which can be placed anywhere along the top. These forks have proved to be indispensable so it worked out great; I got forks and 2 new hooks. I have used these movable hooks 2 or 3 times more than the welded one. This hook option appealed to me because there is no welding or other modification of the bucket. Just another idea.
/ installing hooks on fel #27
That's a great setup Dsmiley.....
That looks very interesting and fairly easy to fab up and the versatility of being moveable, also I was working on fabricating some forks for moving brush and this would work nicely.
/ installing hooks on fel #29
Heck, you could just slide the pin through the hole in the hook and skip the welding and the square tube...
i appreciate all of the input and pics. lots of great ideas and info. still kinda new to forums but am learning to like them, thanks and merry christmas
/ installing hooks on fel #31
Smiley,
Caution on what I mentioned in my post this sbj. The BX25 FEL frame flexs a lot with the center curl cylinder. Uneven loading out on the corners of the bucket could twist that frame especially on max loads.
Ron
/ installing hooks on fel #32
That's what I will try when I get my forks from BXpanded.
/ installing hooks on fel #34
Got my BXpanded forks yesterday and gave them a good workout today picking up limbs, brush ,etc and they were the cat's meow.
Bought some hooks and used the pins like Dave suggested.
Worked just fine.
/ installing hooks on fel #35
:thumbsup: Looks like I might be good for something, at least once in a while! :D
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A61572)
2021 Takeuchi TL6R...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A61574)
2012 18ft Gastron...
Caterpillar 16G Motor Grader Parts and Service Manuals (A63117)
Caterpillar 16G...
John Deere 1023E (A62177)
John Deere 1023E...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
