Diesel versus gas maintance
   / Diesel versus gas maintance #71
i think the cps would just leave you stranded till you grabed the 10mm wrench and spare part and changed it.
I had a CPS that would do just as sandman explained. It would should down or run porly. Start it back up and run fine for sometime hours and sometimes days.
   / Diesel versus gas maintance #72
but did it put you in 'limp' mode specifically? i don't think a faulty CPS would do that.
soundguy
When the light goes on, the truck goes to idle and nothing you can do will make it accelerate. It pulls fine at idle, and never actually shut down. I was in the middle of 5 pm traffic when it did it the last time, and I just idle'd about 2 blocks before the light went out and it started running fine again. I went right by a small shop that has 3 diesel duallys sitting there almost all the time, and almost stopped, just because I wanted to know what was causing it, but opted to go a mile up the road to the auto parts store I generally use, but their scanner definitely was lacking in the diesel catagory.
David from jax
   / Diesel versus gas maintance #74
deffinately sound slike an induced limp mode...
   / Diesel versus gas maintance #76
i know if the ecu thinks something is getting too hot.. like trans, etc, it can kick into limp model. some trucks have a 'wrench' lamp that will come on which limits rpm and kicks out the turbo.. etc.
soundguy
   / Diesel versus gas maintance #77
I had a 2001 7.3 and blew 2 CPS's. Both times the truck would not restart until the CPS was replaced. On our ambulances, same issue when the CPS goes away.
I'm guessing plugged fuel filter. Try replcing that. Pretty easy to do on the 7.3.
Could be you got some bad fuel that plugged the filter.
Again, I'm just guessing here.
Good luck.
   / Diesel versus gas maintance #78
same I've heard on the cps.. it's a stall / go / no go issue.
I keep one and a 10mm wrench in the glove box... taped together.. :)
   / Diesel versus gas maintance #79
Sometimes, but not always. The CPS can create issues that seem completely unrelated to it. Keeping a spare CPS is a good idea, and it takes less than 5-10 minutes to swap it out. Wouldn't hurt to try it and just see what happens.
   / Diesel versus gas maintance #80
so you are saying the cps is putting him in limp mode?
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
19011 (A48082)
19011 (A48082)
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
71056 (A49346)
71056 (A49346)
