Sorry, I know this has been discussed LOTS, but - I have an old Fisher plow blade with two SA cylinders. I have it mounted up front on my Kubota 2350DT and I would like to tie into the hydraulics, adding another valve to control the plow angle. The hydraulic circuit on the tractor goes through the power steering to power-beyond the FEL. I am thinking I can add another valve after the FEL to control the plow angle.
I have a few questions.
1) Can I even install a valve after the FEL to control the plow angle? That is, does the two spool FEL control valve have to have power beyond to do this?
2) Assuming I can install a valve after the FEL, what kind of valve? I think I need a single spool valve, but then things get murky. Closed center? Open center? Relief valve? Crossover? I can't figure out what applies and what doesn't.
3) Does the new valve need power beyond, or is there nothing "beyond" the new valve that needs power, since it just returns to the tank?
I need to be sure I'm doing the right thing, since the valve and hoses will cost more than the plow did. This needs to be as low-budget as possible. It's so low, for the last two winters I have angled the plow manually, but that is getting old. Or, maybe it's just me that's getting old.
Thanks
Thanks
