Did I buy the wrong generator?
   / Did I buy the wrong generator? #51
How long does it take for a full carb to completely evaporate?
   / Did I buy the wrong generator? #52
Good question, and I don't think it would have to completely evaporate before deposits started forming.
I believe that is how stabil works, I think I read it creates a barrier on the surface to prevent the evaporation of important ingredients ??
Was thinking to my self, since I'm in the camp of leaving the carbs full of treated fuel, it might be wise to crack the valve once in a while to replenish the bowl with fuel, between the the maintenance intervals ???
JB
   / Did I buy the wrong generator? #53
I have a 5500w genset with the Robin-Subaru. Have about 100-200 hours on it. Only testing time except for when I loaned it out to friends in LA after Katrina. It performs great, but has always been a bear to start. Almost always have to give it just a whiff of ether. I am in the "run it dry" camp.
   / Did I buy the wrong generator? #54
MossflowerWoods said:
Old Boyscout,
#1 - Why burn Premium? If the engine is designed for 87 octane, then as far as I know there is no advantage to higher octane.
#2 - What additive to the fuel & Why? Stabil? (I've NEVER used it and never had a problem).
I'm really just curious, but I was trained as an engineer and I do nothing without solid reasoning and multiple references to back it up.
Thanks,
David
It is partially a regional thing. With ethanol in the gas, gummed up carbs are common. I have alot of experiance with gummed up carbs, and have rebuolt quite a few.
As far as octane, its a measurement how clean the fuel burns along with other criteria). I agree, its not needed unless called out by a manufacturer.
   / Did I buy the wrong generator? #55
Like most long threads, this one has somewhat gone OT but lots of good comments.
Was surprised to read the negative comments about the Subaru Robins. Have read a lot of reviews from owners of these engines and this is the first ones I've read that were negative. Don't know if all are directed towards the newer OHC designs. I've had one for at least 6 yrs and have to say it is the best small engine I've ever owned. Unlike some small engines, no internal plastic parts in the valve train. Like one other poster said, always starts on the first or second pull. I'd always make this choice if the comp was a B&S. Do admit I'm not a big fan if B&S even though the one I have has served me well for nearly 30 yrs. The warranty, unlike some mfgrs, includes consumers AND commercial duty.
Have a background & experience very sim to MossyflowerWoods and question a few comments made. Never any real issues with todays fuels even though about half the small engines I have sit over winter with fuel in the carb.
Octane is a measurement of a fuel's burning characteristic and the reference fuel is iso-octane with has a rating of 100. See this ref for some info. 2,2,4-Trimethylpentane - Wikipedia, the free encyclopedia Never have seen it used in ref to detergent properties of gasoline.
   / Did I buy the wrong generator? #56
According to our fuel expert at the Experimental Aircraft Association, how fast fuel goes bad depends on where you live. You can store fuel longer in cooler, drier climates: if you live in Florida, don't store it more than about 3 months, northern states are good for 6 months or so.
   / Did I buy the wrong generator? #57
:laughing::laughing: What ever it is.....I am always too late to find out.
But than again it is always easier to pull a completely dry carb off than one that is full of gas.:confused2::confused2::confused2::D
   / Did I buy the wrong generator? #59
I think the exact opposite is true. When you leave fuel in the carburetor it will eventually evaporate leaving behind the "solids" which we call shellac or whatever gums up the carb jets.
FWIW, I am in the shut off fuel and let it run to clear the carb before long term storage. I also use regular gas with Stabil and recycle one year old fuel into my car (well diluted).
+1
Especially true with pre-mix 2-strokes.
   / Did I buy the wrong generator? #60
To each their own. For a long time I only owned Briggs products, and they have been very good to me.
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2015 GMC Arcadia SUV (A50324)
2015 GMC Arcadia...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
