Fuel Consumption GPH
/ Fuel Consumption GPH #1
pak7819
Member
SE Wisconsin
2006 NH TC40DA
Just curious if anyone else tracks their fuel usage close enough to determine gallons per hour. I'm a new member, have had my 2006 NH TC40DA for approx 2 1/2 months. In that time I've consumed ~13 gallons over 26 hrs.
I estimate no more than 5 of those 26 were spent at 2500 RPM bush hogging. The rest was FEL work or hauling wagons back and forth loaded with firewood (heavy).
My wife and I built a house a few years ago and much larger equip that I kinda sorta rented/borrowed from my father in law (bulldozer and track hoe) were in the neighborhood of 5-6 gallons per hour. Granted these machines were mostly under load, but that's all I have to compare against from my own personal experience of offroad diesels.
Just wondering if 2 GPH for my little NH is typical for a 4 cyl non turbo diesel under these conditions or if other owner/operators out there have similar observations to share. At ~$8 per hour to operate, that's not all that bad,...right?
/ Fuel Consumption GPH #2
I have a DK45HST (45 HP) and i reciently found that it took me 6 gal of fuel to plow roads for 2 hours at about 1500 rpm.
other than that, i really havnt tracked it. I only did this to see what i was actually spending on fuel while i plowed the roads to see if i was making any $$$ doint the work. My old JD870 (28 HP) would use 10 gal of fuel every 8 hours.
/ Fuel Consumption GPH #3
According to what you posted, 13gallons/26hours is .5 gals/hour average. More at $2.00 per hour sounds pretty cheap to me.
/ Fuel Consumption GPH #4
i only wish my new L5740 kubota would get better have been really running low <2200 rpm but seem to be doing 3.5gph uggg
Maybe when its broken in
/ Fuel Consumption GPH #5
Yeah I was wondering about the math there. I have a 4320 deere, and although I don't track it, seems pretty similar. I think I could burn a gal an hr if working really hard, and under half gal/hr moving stuff around at 2000rpm or less. I think Nebraska tests run several loads and post fuel burn. A very good resource if you haven't read it yet...
/ Fuel Consumption GPH #6
Yeah I guess now that I think about it, more like 1-2 gal/hr
well what do you know,...i went backwards with the conversion. .5 gal per hour sounds better to me!
/ Fuel Consumption GPH #8
That's about what my L5740 uses when I was plowing, risking, and hauling big bales. I checked the engine spec sheet and it says 3.7 gpm at full power 2700 rpm. Fortunately most of my work is loader, brush hogging, blading, and gathering up bales where it uses a lot less. Our Deere 7730 uses a lot less fuel per acre plowing or cultivating, but we have some small twisty fields you can hardly turn the Deere with its 6 bottom plow around in so I muck around just for fun - they are fields the deer hit hard anyway but they keep the deer out of the better, more open fields where they do more costly damage.
/ Fuel Consumption GPH #9
I have had a 21hp B7510 five years now. The most fuel consuming work is mowing heavy grass - approaching about 1 gph. The rest of the light work such as moving dirt, spraying etc I only had to put fuel in every two weeks - never more than 5 gals.
The 32hp B3200 is using more fuel. The B75 is 3 cyl while the B32 is 4 cyl. I'm thinking I am using 1 gph moving dirt. I also drag a 5' land plane. I'm only running at about 1500-1600 rpms unless mowing.
/ Fuel Consumption GPH #10
My Montana 43 hp uses 1.25 gallons per hour ... thats at 2500 rpm. My Branson 55 hp uses 2.5 gallons per hour at 2500 rpm.
I am a farmer rocket scientist ... the Montana has about a 14 gallon tank and the branson about 24 gallons when they are close to empty I quess the gallons and estimate the time to get the actual estimated GPH.
/ Fuel Consumption GPH #11
My 45 hp Massey has a 3 cylinder Perkins in it. The most common thing I do is mow with a 7 ft. finish mower at 2,000 rpm this is a light load. I've never really checked it but I would guess it's burning 1.5 gph, maybe a little more. I know that a 5 gallon jug can keep me in the seat for quite a while.
/ Fuel Consumption GPH #12
The New Holland TC-29 uses about 3/4 GPH using the backhoe at about 2000 RPM. The engine is not working very hard.
/ Fuel Consumption GPH #13
Back in the day when I was still in the business the design criteria was 1/2 pound of fuel per horsepower hour. Kind of like outboard motors where fuel consumption in GPH at WOT = rated HP X 10%. Rule of thumb to get you into the ball park.
/ Fuel Consumption GPH #14
the last time I paid any attention to it was about a half gal an hour, maybe a little less.
I really do not mind a little more fuel use, keeps me filling her full of fresh fuel that way
/ Fuel Consumption GPH #16
My L3400 (35 HP) burns on average 1 gallon per hour brush cutting, most of my use is less load which = less fuel burned.
Sean
/ Fuel Consumption GPH #17
My BX2230 (22HP) has gone through less than 7 gallons since I got it the end of August and I've put 23 hours on it. 1/3 of that time mowing, 1/3 of it on fairly heavy loader work. Hmmm, must be almost a 1/3 of it joy riding too. :laughing:
/ Fuel Consumption GPH #18
Been a lot of rs since I've done any real work with a tractor. Back when, had a MF165D, Perkinds diesel, and it spent its life making hay, working it hard. Seem to recall I'd have a hard time running more then 10gal in a full days work.
Don't keep close track on the Yanmar and it doesn't get worked very hard. Guesstimating it burns .5-.7 gals hr.
/ Fuel Consumption GPH #19
You're burning 0.5gal/hr, not 2/hr. Sounds about right - my L4200 use is similar.
JayC
/ Fuel Consumption GPH #20
depends a lot on load too, I burn a lot more fuel baleing hay then tedding running about the same RPM but under a lot more load. Tractors are governed, more power required means more fuel to maintain RPM's.
BUSHHOG 3414-14' HEAVY DUTY ROTARY MOWER (A64280)
BUSHHOG 3414-14'...
2012 Ram 1500 Crew Cab Pickup Truck (A61573)
2012 Ram 1500 Crew...
120in. Fork Extensions (A61572)
120in. Fork...
2025 JMR Tree Boom Skid Steer Attachment (A61572)
2025 JMR Tree Boom...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
