Maximat v10-p
/ Maximat v10-p #1
toxicjeeper
N.B Canada
LS 5020c
I am looking at buying a mill and lathe for my shop. I have no idea how to use them or what to look for but i want to learn. That being said i dont need to get a 3 in one ( i have enough space) But this one came my way. He is asking 2500 for it, and has no idea what tooling comes with it..looks like it has a 4 way jaw on it already..Anyway it is a good 4.5 hours drive away so i was thinking of offering 900 dollars. The guy said it hasnt been run in a while and his grand father passed it to him..It looks like quite a bit of rust and i dont mind cleaning but dont wait a basket case lathe..
/ Maximat v10-p #2
IMO you need to find someone who knows what to look for and see the machine in person. We bought a large mill for work and it was an arduous process as many machines looked good but the subtlety of the wear made them bad.
/ Maximat v10-p #3
The machine looks in good shape except for the surface rust. That size is not a production machine so it should not be worn out. Is comes from Europe I think. I use to be a member of a model steam engine building club and that is one of the types that people used.
It works like a ShopSmith wood lathe / tablesaw/ drill press in that you have to re jig to mill or drill.
Your wish of $900 might be alittle low with $1500 maybe tops. If it cleans up ?????????
You could run it for many many years.
I have a small British lathe and a overhauled SouthBend built in 1914 ( 14 " swing )
Craig Clayton
/ Maximat v10-p
Thanks for the replys..He didnt accept my 900 offer.. I am glad in a way cause from what i have been reading unless you can make the parts for these they are very hard to come buy..
/ Maximat v10-p #5
Such a unit severly limits the size of any project you might undertake. Since you have room, look around and find a used Mill & Lathe. It will be worth the expense to pay someone who works on such machinery to check out any prospective purchase. A repair and installation Tech might be contacted through a machinery dealer. They usually service & assess condition of machinery being bought, sold or repaired for customers & the co. Find them under Industrial Supply, Machine tool sales & service..............
Lots of used Equipment on the market due to the economy. Also, watch for Auctions and the classifieds.
/ Maximat v10-p #6
Since size doesn't seem to be an issue, often times a larger machine might actually be cheaper with so many companies closing their doors. Keep watching Craig's list and eBay.:thumbsup:
/ Maximat v10-p #7
Probably a good thing...
/ Maximat v10-p #8
all the companies that sell lower cost imported machine tools now sell some very similar mill/drill/lathe combo machines. i'm quite sure that none of them did any research and development - they just copied something else that was already made. i'm guessing that the machine you looked at is probably the benchmark that the imports were copied from. if you do still end up being interested, it might be worth looking up a parts manual for that machine and the import ones to see if they are in fact the same. i did see an emco site saying that they hadn't been made for over 30 years and parts were scarce, so yeah, a break could be bad since they aren't the most common thing. the other phenomenon i have seen is that with small quirky tools there is usually a following that likes to restore them as much as use them, so demand may put the cost higher than actual production value should be.
as was noted, the smaller the machine, the smaller the work you can do. if space is not an issue, larger tools will give you more work flexibility. around here decent knee mills and lathes will generally run $1500-$2000 each, though in my area there are not often a lot for sale. i've seen people talk about buying them for $500 or so, but great deals are a matter of luck. the one biggest thing i can say is that since they are your first machines, try to get one with a lot of tooling thrown in. tooling and accessories can add up to more cost than the machine in a hurry.
/ Maximat v10-p #9
The machine isn't the expensive part the tooling is. Tooling for a lathe is pretty basic but tooling for a mill can get expensive. I would see if any of your local schools offer a course in machine tools. Not knowing what you are doing can destroy your tooling and machine and could easily injure your self. These machines are gear driven and won't stall out if something gets stuck.
Bill
/ Maximat v10-p #10
2024 John Deere 8R 410 Tractor (A63109)
2024 John Deere 8R...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
2461 (A58376)
2461 (A58376)
UNUSED KJ 25'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 25'X12'...
John Deere 2555 Tractor with Loader (A61166)
John Deere 2555...
