Lines to snow plow??
/ Lines to snow plow?? #1
Airedale
Central NY
Ferguson TO 30 - TYM T433 Cab - Power King 1614
I just picked up a nice used snow plow for my tractor, it has the quick attach mount and the flat skid steer type coupler for angling the plow hydraulics on about three foot lines which I am not at all familiar with.
I am thinking of just having a simple set up made consisting of some lines long enough to go from my rear remotes to reach the male and female flat faced coupler on the plow hoses.
Would I be alright with this setup or is there something more I should know?
Al
/ Lines to snow plow?? #2
That will work no problem. Just did it on my tractor. Mine is a 7.5 fisher plow. Ran quarter inch lines from the rear remote to those 2 angling cylinders. Works like a charm.
/ Lines to snow plow?? #3
yep did the same to my rear remotes, works like a charm.
/ Lines to snow plow?? #4
Yup, will work just fine. Mine are permanently attached. Run under the tractor to a set of quick connects so i can remove the loader easily (in my case i remove loader alot) and on to the rear remotes. Works slick.
Thanks guys, I thought it would work OK, those skid steer style flat faced couplers on the plow lines threw me a bit of a curve because it is the first time I have ever seen them.
Al
/ Lines to snow plow?? #6
Al
my loader mount blower came with the flat faced couplers. And after using them, i much prefer them to the other kinds. They hook up WAY easier even under pressure. Also, theres no way to trap dirt. Too bad there so darn $$$$$ or id would switch all my couplers over
/ Lines to snow plow?? #7
If you do allot of plowing and are concerned about catching the lead edge of the plow on curbs or pavement (or rocks and stumps and stuff).....you may consider adding a crossover relief valve between your cylinders and the control valve.
The crossover relief valve will divert fluid to the other cylinder if / when you hit the plow. Then you just angle it back to its rightfull position after the event.
Some guys feel it is a good thing to have.....and most of the major plow makers furnish such a valve. Like trip springs....it may be good insurance. ;)
Heres a pic of mine.
/ Lines to snow plow?? #8
Here's a pic of my line from the rear remote. On a L2800 think they were 20' when I had them made to reach the plow lines 1/4" in size.
/ Lines to snow plow?? #9
Al
You will probably be dollars ahead to remove the FF couplers and buy two 1/4" or 3/8" ISO coupler pairs to use instead. You don't need the expense or flow capability of the flat face couplers.
I ended up just making up a whole new set of lines with the pioneer type couplers and installing them, everything works perfectly.
I really like this "Cat" brand plow, it is very well made and robust, with it's single horizontal cylinder for angling the plow, it keeps everything compact and close to the loader and not sticking way out in front.
/ Lines to snow plow?? #13
You're right about it being compact and close. That's the tightest most compact FEL plow I've ever seen! Very nice!
Do you have anymore info. on it? Weight, cost etc.
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
PALLET OF HOG CREAT PANELS (A64278)
PALLET OF HOG...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2014 CHEVROLET 2500 SERVICE TRUCK (A64278)
2014 CHEVROLET...
BOUROUGHS 300 GALLON SPRAYER (A64278)
BOUROUGHS 300...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
