Rotary Cutter Landpride RCD1884
/ Landpride RCD1884 #1
90tcom
Like the concept of the cutter fitting close-up behind but looks like is rated somewhat for light-duty. Anybody have experience with this cutter ? Would a 60 PTO hp be too much for the cutter ? Also looked at the SQ84T but looks like it may be high-maintenance.
Thanks
/ Landpride RCD1884 #3
Thanks
I am looking at purchasing an SQ84T. Curious about why you think it would be high maintenance.
I know of 2 SQ84T's that are heavily discounted which I am thinking is because they don't look like the usual shredder.
I demo'd the SQ84T behind a 32 hp tractor. It cut the grass I need to cut, but don't think I would head into a bunch of saplings with it. I lean toward this mower because of lower hp requirements and the offset to the right which to me would lend itself for roadside mowing.
The SQ84T is not as heavy duty as a single spindle 7 foot Bush Hog.
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
White 6182 12R Planter (A66285)
White 6182 12R...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2017 JOHN DEERE 85G MINI EXCAVATOR (A59914)
2017 JOHN DEERE...
