Buying Advice ford 861 powermaster
/ ford 861 powermaster #1
denmeck
Pottsville, PA
John Deere 1026r
Looking to buy an 861 powermaster. Any thoughts on reliability?
Thanks for the advice ..... a bit nervous about whether to buy a used tractor or new
Mowing 25+ acres every week or two
/ ford 861 powermaster #6
Not to talk you out of a really good tractor, but front mount mowers are hard to beat for just mowing.
The 800 would run a 7 foot finish mower, no problem. However, it will be less maneuverable and make bigger ruts than a front mount machine.
/ ford 861 powermaster #7
mowing 25 ac every week or two?
I hope you get an umbrella shade and seat cushion for that 861
they are awesome 48 hp tractors... but it will reasonable only drive a 6' brush mower... with a 6' mower.. you will be mowing easlly 10hrs at a pop... If I was you.. I think I might go for a bigger tractor.. one that pulled an 8' twin spindle mower, or even a 10' mower. I'd avoid the 7' single spindle jobs... too heavy and long. twin spindle are lighter and easier to manage. something like a ford 5000 will run a 10' mower well ( 70 hp tractor ) however a 3010S will run an 8' easilly both good machines.
think about it.
if I was buying a 01 series tractor for serious work.. an 861 would be at the top of the list... especially if it had power steering.. :)
soundguy
Thanks for the advice soundguy...ur a legend on this site.
I will check the 5000.
/ ford 861 powermaster #9
My 860 runs my 7' woods finish mower just fine, but I agree that you should look for something bigger to mow that acerage that often. It would be different if you were doing it a few times a year.
You will have to consider your property too. If you are concerned about maneuverability and ruts, get a big front mount.
/ ford 861 powermaster #10
I guess we need some clarification.
Are we talking about a finish mower???? Or a rotary cutter (bushhog)???
The 861's were good reliable tractors. And very easy to work on and rebuild.
But as with all of them old fords, it is best to stay away from the select-o-speed transmissions. TOO many horror stories
/ ford 861 powermaster #11
i specifically stated rough mower in my comments.. of which an 861 will pull a 6' mower. if finish.. yeah.. 7' is fine.
as for the SOS tranny.. that would be an 871 or 881 powershift gear model.. the 861 is a 5speed dual clutch straight/manual/standard gear model.
/ ford 861 powermaster #12
PS.. there are a ton of good tractor possibilities out there.. perhaps a 4600/4610, 5600/5610
I'd feel ok with an 8' mower on any of those... etc. 10' on the 5xxx
soundguy
I would like to get a 6 or 7 foot flail mower....one I could use for both finish and brush mowing.
It would be mowing common area in my subdivision. Lots of ruts and small swales to maneuver around so your advice is spot on
/ ford 861 powermaster #15
Flail mower? then double the cost of the mower and the times I told you about mowing. flail mowers are natures answer to finding the most expensive way to cut, using more hp per foot than most other cutters, and requiring more time and money in maintenance costs than most other mowers.
i woulod not be optimistic about a 7' flail on that machine.. and forget about 10 hours.. bump that to 15...
flail.. yucky.... :(
soundguy
/ ford 861 powermaster #16
ruts and swales? 5' mower sounds like.. or even a ganged finish mower with 2 decks that can v-fold at least..
soundguy
soundguy
Really? You have quite different opinion than others re flail mowers. Spent a couple hours reading various flail threads on here last night and couldn't find much negative about them
/ ford 861 powermaster #18
My dad ran the poop out of an 800 for years loading round bales...
It is still an excellent "old iron" tractor but needs a fuel pump now...
Take soundguys advice...
He is the ford guru on site...
/ ford 861 powermaster #19
i specifically stated rough mower in my comments.. of which an 861 will pull a 6' mower. if finish.. yeah.. 7' is fine.I know YOU did. But others have mentioned finish. And the OP never said one way of another.
as for the SOS tranny.. that would be an 871 or 881 powershift gear model.. the 861 is a 5speed dual clutch straight/manual/standard gear model.I know that too. But since he is recieving reccomendations about other tractors, and seems to not know a ton about old fords, it was just a general recomendation. Not really directed at an 861.
As to the flail. I have to side with soundguy on this one. If you are mowing every weeks, there isnt going to be a lot of saplings and debris. I would either use a good 7'-8' or so finish mower, which is going to be slow like a flail, but give the best looking cut,......
Or use a bushhog, and keep the blades sharp. It will leave a surprisingly good cut, and be the fastest by almost 2x's
/ ford 861 powermaster #20
Ask people who do alot of mowing what they think about flails. especially people that have to mow for a living / charge for mowing.
Ask Farmwithjunk. he runs a mowing business.
I do alot of ( non charge / personal ) mowing.
I have mowers from 40" on up to 15' I have rough and finish mowers.
I got -0- flail mowers.
to much upkeep, too much maintenance.. too slow.
a rough cut mower will beat a flail in speed any day, and cut heavier material. rough cut mower is cheaper to buy. knives don't fly off either.. don't take 2 hours to sharpen them.
finish mower will make a super nice cut like a finish flail.. and is still cheaper and faster and less maintenance.
just my opinion. you do whatever you want with your money and time. :)
25 ac on a 5-6' flail? better build a bed and toilet into that tractor as you may be mowing it on a permanent basis... maybee setup an in-flight refueling setup so you don't loose any time stopping to fill the tank, as you will need that time to MOW.
i reccomend a nice comfy chair, and ros with a topper / sunshade, a drink cooler holder, and a place to store some sandwiches. I also reccomend a good set of headlamps as you will be mowing in the dark alot trying to keep up with that much mowing on that machine and mower ;)
soundguy
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
Tandem Axle Rear Truck Frame (A61568)
Tandem Axle Rear...
(APPROX.16), 40"X118" INSULATED PANELS (A62131)
(APPROX.16)...
