Rust getting bad all over my Kubota
   / Rust getting bad all over my Kubota #21
Kubota uses primer, I've got rock chips from bucket spill onto my hood, primer is plain and clear.
Is your hood steel? I don't know about Kubotas, but most of the tractors I have seen have plastic hoods.
   / Rust getting bad all over my Kubota #22
The paints in most industries during those years were moving from oil based paints (really good) to water based paints (really bad). The first of the water based paints were crap, and that maybe whats on those years of tractors. Not sure what the EPA type laws in Japan were then controlling paint. My bet is the paint is failing and allowing moister to penetrate those areas were two pieces of metal rub together and expose metal to metal in those seams, they do move. More modern water based paints are better but will likely never match the oil based stuff from old. If you do nothing they will continue to rust.
HS
   / Rust getting bad all over my Kubota #23
Steel hood on most all kubota's. Very little plastic besides the roof panel.
   / Rust getting bad all over my Kubota #24
Funny...
I just finished spending about 20 hrs disassembling/sanding/priming/repainting most of my 2008 b2920
Looks good sorry no before or after pics
One thing I did notice was the primer/metal showing through underneath the floorboards, inside engine covers and other inconspicuous places
Looks like only 1 coat of paint was applied or maybe even just some overspray
Anybody else have the same issue?
You would think for the considerable $$ invested you would get powder coating or good paint!
   / Rust getting bad all over my Kubota #25
There is something about the old steel that just didnt rust up like the new stuff does. Take a look at any old implement that has been setting out in the weeds for 40 years and they mostly are not pitted up with rust, most will just be lightly rusted and then seem to just stop at that point. Maybe it was the paint also.
I've always wondered if it's due to the new stuff is made from recycled steel that has been recycled hundreds of times with who knows what impurities in it when the older stuff may have been made with virgin steel.
The stuff that is rusting today:
Cheap paint and applied thin
low grade steel
   / Rust getting bad all over my Kubota #26
Interesting thread, could be quite a few reasons why. Bad or not enough paint , little or no primer, lighter gage steel, environment where you live. Up here in up-state N.Y. the winter salting of our roads play's H*** on any exposed metal parts on cars, trucks or tractors that travel in it.After a large snow storm our roads are powder white and the salt dust is every where in the air. I need to wire brush and paint my class V trailer hitch on my F350 each year because it looks so badly rusted.
DevilDog
   / Rust getting bad all over my Kubota #27
My 09 L3400 is rusting in the same place GlennaR's is, on the right side rear fender seam. I've tried repainting the seam and spraying it with Fluid Film and Rust Check, we'll see if gets worse. I suspect it will, I doubt there's any paint between the seam joints.
Sean
   / Rust getting bad all over my Kubota #28
Funny...
ericher69. Did you do just the sheet metal? Did you do it yourself or take it somewhere else to get painted?
   / Rust getting bad all over my Kubota #29
Only did visible rust with the die grinder
Sheet metal of fenders, steps, engine shrouds
Also front mount blower, Chute, skid shoes, cab, rear blade
Spray can from kubota and TSC/Valspar
   / Rust getting bad all over my Kubota #30
My guess would be recycled steel .... it is not like it used to be. Get some marine caulk and caulk the joints, they will stay flexible and you should be able to paint over the caulk ..stay away from silicon ..it does not paint. I did a horse trailer this way 5 years ago and no rust, Remember rust never sleeps :D
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
KOMATSU D65PX-16 CRAWLER DOZER (A60429)
KOMATSU D65PX-16...
