O/A Welding Question
/ O/A Welding Question #11
I agree. Oxyfuel is not the best when welding two dissimilar thicknesses of steel. At least not for those of us who don't have loads of experience.
A cheapo wire feeder or stick machine would do the job in a few minutes.
Agreed, I would only do it if it's the only option I had. A few tacks with the mig and a nice bead would be the norm. Gas welding is 19th century but it looks like someone is still doing it. I like it all.
/ O/A Welding Question #12
I find gas welding much more satisfying and like to use it for sheet metal where it gives much greater control than mig or stick but it clearly is slower.
Are you determined to gas weld it and avoiding arc welding? or just don't have an arc welder? IMHO.. your task would be a couple minute job with an arc welder..etc..
soundguy
I don't have nor do I have access to arc or MIG. Maybe some day but I have been watching out for an old AC/DC tombstone but have not found one yet.
I have seen a lot of MIG that just does not get the penetration on thick material. If I go for the fish-scale look with OA I don't get the necessary penetration when working thick material.
/ O/A Welding Question #14
TF, I'm in the 98446 area, if ya want and it's not a large project, bring it by.
/ O/A Welding Question #15
Even a $99 HF fluxcore machine could stick your two pieces together. It cannot penetrate more than 1/8 inch but if the smaller piece is that thickness or less there is no benefit to greater penetration on the thicker piece.
/ O/A Welding Question #16
why don't you braze it ? it is easier than welding.
/ O/A Welding Question #17
T joint with tube to base metal is not ideal for brazing but you are right it could be done. I guess it depends on how strong the joint needs to be.
/ O/A Welding Question #18
northern tools has a 140$ stick arc welder.. 200a I think. probably low dutty cycle like 10% at that range.. but around 100A should be fine.
good and cheap.. make jobs liek that pay forthemselves fast in gas cost alone pretty soon. acetylene here is sky high..
soundguy
/ O/A Welding Question #19
soundguy
I would first take a look at craigslist. I got my tombstone, a nice pipeliner helmet, a pound of 6013 rods, an extended stinger cable, and a bernard shortstub electrode holder, for $125 or $150. About the same as the northern, but will last a lot longer, and comes with some nice extras.
/ O/A Welding Question #20
i would look there too.. but I believe he said he couldn't find anything used.. so just kicked out the idea of that low end / limited use one. for jobs like this.. it's cheap and will burn rods. a good used tombstone IMHO.. would be my choice too though.
soundguy
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
2006 GMC C5500 4X2 BUCKET TRUCK (A59906)
2006 GMC C5500 4X2...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
