Yanmar YM186 power steering question
/ Yanmar YM186 power steering question #1
mnoonan
I purchased a used "All in one power steering unit" with a YM186 tag. Could someone tell me what the GPM requirements are for this or any other Hydraulic information you may have. I am adding this power steering to a Case/Ingersoll 226 Garden Tractor and trying figure how to plumb this into the system and do I need to go with a larger pump, etc. Any help would be appreciated. Thanks in advance,
Mike
/ Yanmar YM186 power steering question #2
If you purchased the whole unit, it should have a flow divider that sends the first 1.5 gpm to the p.s. cylinder and the rest to a bypass hose that goes up to the loader or back to the three point hitch.
The "all in one power steering unit" I have is in the attached picture. The original pump on the Case/Ingersoll is a Parker D27X08 and puts out about 8-10 GPM @ 3600rpm. I will not be using any other hydraulics other than for power steering and the travel motor. I have been thinking about replacing the original pump with a Parker H31 or H39 with a secondary port dedicated to the power steering. By the way this will be a modified garden tractor powered by a 1949 Ford flathead V8 but to be used like a golf cart.
What is the pressure req'd. to the power steering i/e the relief valve setting in the diverter valve.
/ Yanmar YM186 power steering question #6
The 1200psi is the relief valve setting + or - 100psi. Manual states that is preset from the factory. Sorry I didn't include that from the start.
Thanks winston1
/ Yanmar YM186 power steering question #8
mnoonan, where did you buy that and did they have another one? How much?
JCByrd24, I purchased the used power steering unit from Jim's ATV Salvage in Porterfield, WI. His phone # is 715-789-2906. I paid $30.00 for it. I don't know if the have any more.
/ Yanmar YM186 power steering question #10
That is a great deal! If you do not end up using this let me know, I will gladly buy it off of you (unless Jim's ATV has another one)
/ Yanmar YM186 power steering question #11
I still have a new flow diverter block in stock for that power steering unit, if you are interested, pm me.
FLATBED 6 WHEEL COTTON TRAILER (A63291)
FLATBED 6 WHEEL...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
(3) METAL SINKS (A63291)
(3) METAL SINKS...
2020 ASV RT65 (A60462)
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
