2" Receiver Solution for X749
/ 2" Receiver Solution for X749 #1
tiger9a
Orlando/Sebastian, Florida
JD 425
Howdy All -
I am getting ready to pull the trigger on trading in my JD425 AWS on a new X749. One of the things I use my 425 for is jockeying trailers around for storage on my property. One of my trailers has a 2" ball and another has a 2 5/8 ball. As you can see from the picture of my 425, I had a buddy weld a 2" receiver to the rear weight bracket which, allows me to swap out to the correct ball size.
It looks like there is an add-on 1 1/4" receiver for the X700 series but that will never accept the ball sizes I need and is way too low to the ground. Can anyone out there help me with any ideas on how to get there? This is by no means a show stopper...I just hate to spend that kind of $$$ on the new machine and not have the utility I have with the setup on my 425.
Thanks in advance for any advice!
/ 2" Receiver Solution for X749 #2
2-5/8? wow, big trailer for a 1000 lb tractor.
i used the front 1-1/4 receiver for some trailers
(comes standard in X7) but never tried to
move my travel trailer with that big ball.
i would imagine you could get a machine shop to weld on
a piece of plate to any 1-1/4 ball mount to make room for
a hole large enough to mount the big ball on. then use another
standard mount for the 2", quick change between the 2.
you have that current hitch up pretty high, ever get
light in the front end with the big trailer on it?
/ 2" Receiver Solution for X749 #3
Check with Tractor Supply's tow hitch pages. I believe they have a class 1 to a class 2 upsize adapter.
Dutch - They are aluminum boat trailers and I only move them around empty (boats are on lifts at the dock). The 425 moves them around just fine. You can also see from the pic that I have a JBSr bucket on the front of the machine...couple of cinder blocks in that and the front stays down just fine when moving the big trailer around. The ball is up a tad high but works just fine because I usually set the tongue jack on a block and only have to come up the height of the ball to get it off.
I guess I could have something welded up...I just notice that the receiver adapter they sell for the X749 goes on the bottom of the current hitch plate so whatever I have made up will have to come up quite a bit higher.
imgone - Thanks for the pointer will take a look at TS and see if I can find and adapter!
I'll keep you all posted on what I come up with...
Thanks!
John that makes the JBSr also tells me the front bracket works on both the 425 and the X7 series tractor without a mod so the hole pattern dimensions are identical on the front. I am wondering if the rear frame hole patterns may be the same too..?
/ 2" Receiver Solution for X749 #6
In this pic you can see the JD hitch they make for the X7XX's that I installed on mine. The directions say to mount it under the hitch plate and I agree it's to low. With the holes that are in the hitch it self you can mount it on top of the plate if you want to make it higher and it should be stronger sitting on top of the plate vs hanging under it.
Like the others have said I just got a adapter that goes from a 1 1/4 to 2" and you can run what ever size ball you want.
/ 2" Receiver Solution for X749 #8
No prob. good luck on the new X749 purchase!
/ 2" Receiver Solution for X749 #9
There's some fairly large "drop" hitches out there,
turned upside down they become a "raise" hitch huh?
From E-trailer website:
Yep...thanks for the pointer to the e-trailer website. Looks like I'll be able to find everything I'll need to make it work there!
I went to the JD dealer over lunch and put the deposit on the tractor and made the order official. The new machine should be here 12/20 at the latest...nice Christmas present to myself!
Thanks to everyone for all of the input. I found a 1 1/4" ball mount with a 5" rise and a 2" vertical receiver adapter on e-trailer. I'll have the 2" receiver adapter welded to the ball mount. I'll order the hitch that bruce has on his machine and I should be good to go.
/ 2" Receiver Solution for X749 #12
Are you going to get a 3 point for the x749? If so you can get a 3 pt receiver.
Then you can raise the ball as you need.
Timber - I did think about that as a solution too but I am not that familiar with what the 3 point hitch does for you (I'm sure many things but I am new to it) and I really only use my tractor for mowing, moving my trailers, and light duty earth moving with my JBSr. When I looked up the cost for going that route it was $700 plus for the equipment. If I knew for sure I had other uses for the 3-point I might be able to justify it but for now I'll just go the simple route.
/ 2" Receiver Solution for X749 #14
Since you already have the adapter it wouldn't be too hard to weld up a bracket to raise the location of the hitch. Or, you could mount the hitch on top rather than under the plate or buy one of the hitches posted to raise it up.
/ 2" Receiver Solution for X749 #15
Congrats on the new unit!
you will love the diesel!
(wish I had one myself sometimes)
make sure you get us some pics of your
new trailer hitch setup too.
:D
:D
Will do...I'll be sure to update the thread with pictures!
/ 2" Receiver Solution for X749 #17
your talking about moving boats/trailers the rest of
us are talking about moving snow :(
Believe it or not, I'm kind of envious of you guys up north using your machines to 'play in the snow'. Seriously...I love some of the youtube videos out there of the JD garden tractors blowing snow....looks like a hoot to me!
/ 2" Receiver Solution for X749 #19
tiger9a,
I have found alot of uses for the 3 point hitch and 540 pto on my x749, works well with landscape rakes, chipper, boxblade, rearblade and pine needle rake.
Congratulations on your new mower, I am very satisfied with mine and think you will be too.
tiger9a,
Thanks Steve...I'm gonna miss the good ol' 425 but I'm also sure the 749 will ease the pain! Thanks for the bullets on the 3 point attachments. I need to do some research and see if there's anything that will come in handy for me.
2017 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2025 60in Hydraulic Forks and Frame Skid Steer Attachment (A66734)
2025 60in...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Kivel QA Pallet Forks (A64912)
Kivel QA Pallet...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
