Wild KAT attachments
/ Wild KAT attachments #62
Called the dealer to see if they offered one. They do not. The salesman had concerns of even putting a grapple on such a LD loader as the 400x.
He sounds uninformed. He also must not read his own (JD) implement literature. JD offer several grapples to fit on the 400x :laughing:
/ Wild KAT attachments #63
The salesman is FOS.
Interesting you mention that:
When I was calling around to various dealers to find a SSQA adapter for my L3400HST, one of the dealers I spoke with said there was no use putting one on such a small tractor as the lift ability just wasnt enough to bother putting on pallet forks or anything else on it anyway.. I politely thanked him for his advice and continued calling until I found a good price on the OEM SSQA adapter from a dealer about an hour away. Who delivered it and a new bucket and helped me put it on. I have used the forks for many things and find them quite useful. I am not sure I have enough use for a grapple to justify buying one, but I may at some time.
So yes salesmen are often FOS
James K0UA
/ Wild KAT attachments #65
I got my 66" WildKat extreeme rock Grapple in and all I can say is WOW this thing is extreemly heavy duty and well built. It is much bigger and beefier that I had anticipated. It may actually be to big for my M5040 tractor. This is the 66" grapple with the rock bucket bottom and teeth.
A picture of it is in the upper left hand corner of their web page: http://www.wildkatattachments.com/grapple.html
/ Wild KAT attachments #66
Virtually no CUT sized machine including the relatively light M series really needs any grapple weighing more than about 400 lbs. Anything bigger is designed for a skidsteer and will only cut your net lift capacity. Sadly none of the grapple manufacturers seem to understand this simple axiom as they do 95% of their business with commercial skidsteer owners.
/ Wild KAT attachments #67
A picture of it is in the upper left hand corner of their web page: WILDKAT ATTACHMENTS - Miscellaneous
It's a little on the heavy side at 700lbs, but unlless you're using it at max cap. all the time you should be ok. If you think it's too heavy of a load just take less. I ran my 500 lb 66" grapple on my old LA854 loader and never had a single problem. Just make sure you have enough ballest.
/ Wild KAT attachments #68
whitedogone said:
I'm coming from the rear remotes forward along the left side of the 4120. Mounting a bulkhead on the tube that the 400x loader sits on and another bulkhead out the loader arm itself.
Here's the JD kit on my 4120.
/ Wild KAT attachments #69
As stated before or elsewhere on TBN, I bought the bottom half of Wild Kat's 66" wide "HD Deep" grapple (just the bucket part), for $700, & it is massive; Prob meant for a skid steer. 1/2" steel for almost everything. It's also looong; I haven't measured the teeth, but they must be 3' long. All this adds up to: My lifting & curling capabilities seem to be greatly reduced. I can't curl things that I think I previously could with my OEM Kubota bucket.
I hate to complain about something being built "too tough", but this probably is, for my tractor anyway. I think it would be better if the steel was 3/8" thick instead, & if the teeth were at least 6" shorter, if not 9" or 12" shorter.
/ Wild KAT attachments #70
:D I think you have just described a light duty 48 inch grapple as being ideal. I agree completely.:laughing:
/ Wild KAT attachments #71
Island, you have been preaching this sermon for quite awhile. I saw the light and have been trying to turn the flock on to the Wildkat econo 48" grapple, but our work is not yet done. (Cue choir).
/ Wild KAT attachments #72
I had the same Quick Tach pin fit problem on both the Root Grapple and Stump Bucket I bought from Mid-State Equipment around 2005. I simply welded in shims as my pics show. Well worth it for the price.
Also my Root Grapple weighs around 600 lbs, but it hasn't slowed me down at all! I do have a Kubota L3430 so my tractor isn't real small.
ksmmoto
/ Wild KAT attachments #73
Oops, I didn't have any pic's of the shims I welded in. I'll get some tomorrow and post then.
ksmmoto
/ Wild KAT attachments #74
I was going to start my own individual thread, but will just add everything here.
I originally was looking for something different then what I got, the 48" WK econ grapple. As I mentioned before, this on my 28hp tractor is a little overbuilt. The crossbars could be smaller and this has more gussets then I think is necessary.
I was going back and forth about setting up a diverter valve or use my rear remote, and ended up just moving my remote valve to the top of the right fender. It's easy to go back and forth between the FEL lever and remote valve and saves the complexity of more fittings, valves and wires. I used 3/8" hose from Discount Hose (PA), pre-measuring the amount needed with a garden hose. A Parker Pioneer Break-Away Clamp 5006-4-CS was bent and bolted up on the boom crossbrace to work as a bulkhead.
I've used the grapple for a few days cleaning up after trees that were bulldozed, cleaning some dropped branch areas, and tearing out some Hemlocks that were over grown. And lately have been using it for transporting cut Christmas trees.
I set this up on my Ford 1710 using a Long QA adapter. One of the issues that has been coming up is loose fitment to the QAs, but I don't see that as an issue here. The top brackets fit up fine and the only time I have a little play at the bottom pins is when I curl backwards all the way, and then the 1/4" pin play shows up.
In some ways I need more of a root rake as the gussets on the front teeth act like a solid blade with the fibrous roots of hemlocks or scotch pine, defeating the ability to shed soil between the tines. I doesn't help that the soil is moist right now either.
With Christmas tree selling time here, I removed the upper grapple to carry the trees a little easier. With the top jaw it's a little harder to get trees onto the lower teeth, and customers are not going to be thrilled seeing their tree clamped down on.
With the top grapple off I've also used it to dig out some 12-14' hemlocks. Not an easy task for a little 1710 and the reduced weight without the top jaw gives me a little more hydraulic lifting force.
With the factory setup you have to unbolt the jaw at three points, pull the cylinder retaining pin clip and detach the hydraulic QCs. This is actually easy by itself, but I've ordered pins to take the place of the bolts so it's even easier. Since the bolts also act as the pivots on this economy grade grapple, the changeover to pins will relive the threads of the bolts from acting as the pivot points. These are not greased and in this operation I see no need to do so.
In the future I may reduce or eliminate the gussets at the front teeth. Maybe in rocky soil or with a 50hp tractor they would be needed more, but if they would bend they could be easily straightened.
Up at the top jaw I also see no need for the outer jaw gussets. That little cylinder is never going to generate that much force, and the outer gussets prevent the top grapple from curling in more to secure your load.
So far this has been a good strong unit and I could not find any issues with the welds, and I'm cert'd to teach welding.
/ Wild KAT attachments #75
ksmmoto
Island got real quiet after you posted those pictures, somebody should check on him, he might be out kicking and swearing at his 48" single.. :laughing:
/ Wild KAT attachments #76
Nah, just spending quality time on Amazon trying to decide which Makita 18V setup Santa wants to bring me for Christmas.:D
Lifting brush (as in the photos just posted with the too muscular grapple) is almost never limited by weight as brush is just not heavy. The limitation is grapple opening and how well you cram the stuff in. The weight limitations come with lifting big logs, rocks etc and to some extent the ability of the grapple to curl stuff out of the ground like roots (in that case the grapple weight is actually largely on the ground).
It actually doesn't take much to overload a Kubota L (not trying to start a color war here) as the Kubota loaders are pretty conservatively sized. As I recall the under 40hp loaders max out at about 1500lbs lift or so. Deducting a few extra hundred pounds from that can make a difference with big logs, stumps etc. Indeed, my old CK20 had a lift of about 1100lbs and with a 300lb grapple could probably lift pretty much the same load as a Kubota L3400 mounting a 700lb grapple. Of course if the Kubota L3400 used a 300lb grapple it would lift much more.
Photos show CK20 with light duty grapple lifting big pile of brush (again, brush is a volume challenge not a weight issue). Other photos show DK40 lifting near max loads with light duty grapple. I probably could not have lifted these if my grapple weighed another few hundred pounds.
(edit: sorry I kept referring to a 700lb grapple rather than a 600lb but the basic point is the same).
/ Wild KAT attachments #77
We just need to bring the sinners back into the fold. They mean well but the devil has instilled evil thoughts of more horsepower, bigger grapples etc into their minds. We'll get them back.;)
/ Wild KAT attachments #78
sears has the 19.2 v. Crapsman on sale for about $35. I've been using one of them for about 10 yrs., might grab another, mine's been un-killable. :thumbsup:
/ Wild KAT attachments #79
Jake, while I liked my Craftsman pretty well, the battery died after a few years and I got a Makita, which has proven to be much longer lasting. My .02.
/ Wild KAT attachments #80
Don't want to hijack here but after a couple of Costco "Kawasaki" sets I've learned my lesson. The Makita LXT lineup is REALLY nice. These new 18v lithium tools are amazing. For example a battery powered 325ft/lb impact wrench! Santa might get me the basic drill plus driver kit and I'll see how it goes from there.
Maybe I'll get the impact wrench ($145 bare) with some of the money I saved by getting a light duty 48 inch grapple. There, we are back on topic.
1984 International 2275 Spreader Truck, VIN # 1HSZAL7N9EHA37851 (A61165)
1984 International...
HYSTER H80XL STRAIGHT MAST FORKLIFT (A62129)
HYSTER H80XL...
2013 Hyundai Volster (A61569)
2013 Hyundai...
2014 JOHN DEERE 35G EXCAVATOR (A62129)
2014 JOHN DEERE...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
