Tractor size versus bushhog size
   / Tractor size versus bushhog size
I think if you cut things at the right time of the year that reduces some of the hassle of possibly having to big of a bushhog as well for the most part.
   / Tractor size versus bushhog size #32
I use an 8ft pull-type behind a M5040,no problem at all. 3 point gonna say 7ft max,just cause of weight. I have used our 12ft pull-type in lighter stuff,but havent tried it in heavier stuff yet.
will the pull behind allow you to go on steeper inclines?
Why can't you convert a bushhog into a pull behind. With some fancy wheel attachment gizmo
   / Tractor size versus bushhog size #34
Sure you can, just need,cutting torch,welder,hyd.cylinder,and a few pieces of pipe and brace material and have at it....Will need to find longer pto shaft... LP3596.jpg here is a pics of mine for you
   / Tractor size versus bushhog size #35
We went from a 3PH Woods 121 to a pull type DS1261 and even though it is heavier, it is more stable on slopes going up/down as well as across side slopes. Unlike foreman Etexas, ours hooks to the draw bar rather than 3PH; never used a semi-mount, so I don't know anything about them.
   / Tractor size versus bushhog size #36
Naw,TripleR the picture was just taking up close.It does hook up to drawbar,I think they just have a standard deck with the semi-mounts from factory already on there.I guess you could use it as a semi-mount with shorter shaft but dont know how rear tires wouldnt dig in while turning since rear tires are fixed.
   / Tractor size versus bushhog size #37
Yep, should have noticed the rear tires. We thought about a semi mount, but couldn't really see any advantage to it.
   / Tractor size versus bushhog size #38
Sure you can, just need,cutting torch,welder,hyd.cylinder,and a few pieces of pipe and brace material and have at it....Will need to find longer pto shaft...View attachment 240484 here is a pics of mine for you
Why not just put guage wheels on the front and leave the toplink disconnected.
No need for an expensive longer PTO shaft
   / Tractor size versus bushhog size #39
Your saying set it up like a finish mower,basically...
   / Tractor size versus bushhog size #40
similar.
Instead of pulling from a drawbar, just pull from the lower links. When mowing, have the 3PH all the way down and let it "float".
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2011 BMW X5 SUV (A50324)
2011 BMW X5 SUV...
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
