Tractor size versus bushhog size
   / Tractor size versus bushhog size
I think if you cut things at the right time of the year that reduces some of the hassle of possibly having to big of a bushhog as well for the most part.
   / Tractor size versus bushhog size #32
I use an 8ft pull-type behind a M5040,no problem at all. 3 point gonna say 7ft max,just cause of weight. I have used our 12ft pull-type in lighter stuff,but havent tried it in heavier stuff yet.
will the pull behind allow you to go on steeper inclines?
Why can't you convert a bushhog into a pull behind. With some fancy wheel attachment gizmo
   / Tractor size versus bushhog size #34
Sure you can, just need,cutting torch,welder,hyd.cylinder,and a few pieces of pipe and brace material and have at it....Will need to find longer pto shaft... LP3596.jpg here is a pics of mine for you
   / Tractor size versus bushhog size #35
We went from a 3PH Woods 121 to a pull type DS1261 and even though it is heavier, it is more stable on slopes going up/down as well as across side slopes. Unlike foreman Etexas, ours hooks to the draw bar rather than 3PH; never used a semi-mount, so I don't know anything about them.
   / Tractor size versus bushhog size #36
Naw,TripleR the picture was just taking up close.It does hook up to drawbar,I think they just have a standard deck with the semi-mounts from factory already on there.I guess you could use it as a semi-mount with shorter shaft but dont know how rear tires wouldnt dig in while turning since rear tires are fixed.
   / Tractor size versus bushhog size #37
Yep, should have noticed the rear tires. We thought about a semi mount, but couldn't really see any advantage to it.
   / Tractor size versus bushhog size #38
Sure you can, just need,cutting torch,welder,hyd.cylinder,and a few pieces of pipe and brace material and have at it....Will need to find longer pto shaft...View attachment 240484 here is a pics of mine for you
Why not just put guage wheels on the front and leave the toplink disconnected.
No need for an expensive longer PTO shaft
   / Tractor size versus bushhog size #39
Your saying set it up like a finish mower,basically...
   / Tractor size versus bushhog size #40
similar.
Instead of pulling from a drawbar, just pull from the lower links. When mowing, have the 3PH all the way down and let it "float".
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52128)
2000 John Deere...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
