Front tires for L4200
/ Front tires for L4200 #1
urd505
Kubota L4200GST
I bought a used L4200 w/FEL,the front tires need replaced,but,it looks like it has skid steer type tires on it now...whats the best replacement?Thanks
/ Front tires for L4200 #2
Sounds like they are R4 tires. Is it a 4WD tractor? And, are the tires on the rear the same type? If so you should match the front tires to the rear or you may damage the drive system.
/ Front tires for L4200 #3
I don't know about the "best", but I just replaced the front tires on my 5030 with Titan 8 ply tires. We have used several brands Goodyear, Mischeln, Firestone, Titan and really couldn't tell any difference in any of them.
It's a 4 wd...How would the tire choice damage the drive train? Thanks for the input?
/ Front tires for L4200 #5
The short and simple version is that the drive system is a single system and must be mated so that the tires turn at the same rate. Different tires that are not matched could prevent this hence drive system damage. There are a lot of threads that have addressed this in depth, you can use the search feature to find them.
/ Front tires for L4200 #6
I don't know that you'd actually damage anything with slight mis-sizing, BUT from a design and/or performance standpoint, the tire size must be correct relative to the rear, such that the front wheels overdrive the rear by 2-5%.
Required front/rear tire sizing for the different types of tire are in the owner's manual. Awesome tractor, BTW.
JayC
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
43018CFL (A59228)
43018CFL (A59228)
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
John Deere 757 Zero Turn (A63116)
John Deere 757...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
