Fixing a road
/ Fixing a road #1
teg
Super Member
nowhere
s
This wasn't much work... The ditches got full and some water was running down the road instead of the ditches... This is the upper section.
/ Fixing a road
This is the lower section... just dressing up the ditch.
/ Fixing a road #4
Teg, did you grade it flat or put a crown on it? I can't tell by the pic's. My driveway is pretty steep, if I don't crown it the water just runs down the wheel tracks until it makes a gorge.
/ Fixing a road
Good eye :confused2: :) This section is on the list to be regraded once we move up there. There is a *very* slight crown and most of the water runs off except when the wheel "depressions" show back up.
When that happens I cut little side channels to help the water get into the ditches and use the dirt/gravel from the side channels to block the water from going down hill any farther.
/ Fixing a road #6
Yep, that's how I do mine. It is one of those thing that will always have to be done. My neighbors driveway is as steep as mine. He had it tar and chipped 6 years ago($35K) and now it is in need of repairs. Steep grades cause a host of problems as the years go by.
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
CAT 988B Final Drive (A68134)
CAT 988B Final...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2015 FORD F-150 (A67714)
2015 FORD F-150...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
