Canopy Got LED Work Lights Installed
/ Got LED Work Lights Installed #1
caspar3259
Forest Ranch, CA
Kubota L3540
I was able to get the 4 work lights installed over Thanksgiving week. I went with these LED lights from TowMart which are 18 watts, 1600 lumens, and draw about 1.5A each.
I mounted them to the existing bolts holding the canopy, which seems to work great for the front and OK for the rear. The canopy bracket prevents the rear lights from being tilted downward much, but I think it will be OK.
For power I tapped into the 10A work light circuit at the fuse block and put the switches in the blank panel to the left of the seat. I chose marine toggle switches as they are supposed to be water proof. These are rated at 25A for 12V, so should handle the load fine without the need for any relays.
When I was first buying materials for this project I underestimated the amount of wire I would need. Seemed like 20 feet would be plenty, but ended up using more like 50-55 by the end. I did "home runs" for each lamp back to the switch. Probably overkill, but that way I minimized the number of connections... well, at least I consolidated them all at the switches where they are more protected.
My first test of the lights at night went well -- I think it will be plenty of light. When there is snow on the ground it will seem even brighter.
Jeff
/ Got LED Work Lights Installed #2
Thanks for the post and pics. Just ordered four of those light for my kubota L3130. Hopefully they will help with snow removal this winter.
/ Got LED Work Lights Installed #3
I installed a similar set of LED lights during the holiday as well. Something must be in the air...I needed extra lighting to see beyond my bucket/snowplow. Nice job on the install.
/ Got LED Work Lights Installed #4
They look good . You would think manufacturers would make lights standard equipment , especially with a fel .
/ Got LED Work Lights Installed #5
Looks great! :thumbsup: I'm jealous! I need to get motivated. Of course I have headlights, but the loader blocks them too much of the time, even though I'm now using this open-back grapple bottom bucket (surprising how much light those two horizontal box beams block while using the loader):
attachment.php
The lights were a bit pricey, but I wanted something durable with good light output and low current drain. So LED was the choice. I'd rather pay more up front and be done with it.
Looking forward to LED lighting prices to come down over the next few years so I can use more of them in the house. I don't really like the look of the compact fluorescent bulbs we have now.
-Jeff
/ Got LED Work Lights Installed #7
Looks good--I was going to put mine on the front of the canopy rails but was concerned I'd bump my head on them. Let us know if that's an issue--if not I think I'll move mine.
/ Got LED Work Lights Installed #8
Jeff
How about some night shots???
Interesting idea! I didn't think it would work well, but I'm amazed at the difference.
All three pics are from the seat: first with standard headlights (low beam), second with front work lights only, third with rear work lights only.
The work lights sure light up the area! "Flood" is the key word here. I think the rear lights look brighter because there are objects close to the tractor. At the bottom of the rear pic is the back edge of the box blade.
I just looked at the exposure settings for the pics and the first two are the same: 1/8 second @ F2.8. The rear photo was 1/10 second @ F2.8. This tells me the increase in light you see between the first two is solely due to the work lights.
Jeff
Hmmm... I haven't noticed it in the way. I think they don't get in the way because as I climb the step I am headed toward the seat away from the light. I'm 6' 2" and it works out, but someone larger might have more of an issue.
Edit--> If the lights are bigger or canopy slopes down in front it might also be more of an issue.
Jeff
/ Got LED Work Lights Installed #11
Nice work. That's the best work light set-up I have seen posted to TBN. Seriously, well done :thumbsup:
/ Got LED Work Lights Installed #13
Jeff- that looks like a wise investment- excellant quality light, low draw, and no need to ever replace bulbs! (Well, don't they say 50,000 hours?) Your night time pictures tell the whole story.
/ Got LED Work Lights Installed #14
50,000 hours is only 5.7 years of running them 24 hours a day, 7 days a week, 365 days a year.
/ Got LED Work Lights Installed #16
So you're saying if I only use them at night they should last over 10 years? :laughing:
Ha-ha! Yes I am, sir! :laughing:
Realistically, since you're prob not a pro, & prob don't do mostly night-time work ... they're probably gonna last you forever. :D :thumbsup:
(I just knocked on wood for ya)
/ Got LED Work Lights Installed #17
Nice job! I actually just got my LED lights yesterday (very similar to the set you got, but mine are 18W, 1350 lumens, ~1.5A draw). I'll be posting pictures once completed with my install.
/ Got LED Work Lights Installed #18
Thanks for the pics taken in the dark. Lights seem to work really well. Mine are being delivered tomorrow and hopefully it won't be to bad putting them on as it's starting to get pretty cold out there.
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Lincoln SAE-400 Shield-Arc DC Arc Welder - Inoperable (A63689)
Lincoln SAE-400...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2001Chris Craft Boat with a T/A Boat trailer (A61574)
2001Chris Craft...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
