SUDT vs UDT for BX-24 Official Kubota Recommendation
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #11
I thought that Kubota came out with a new oil that replaced UDT and SUDT (SUDT II or something like that)...?
It replaced SUDT, not UDT.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #14
Since UDT's viscosity is near that of SAE 10 when it is cold and near that of SAE 30 when it is hot, why is it not considered a multi-viscosity oil?
Info I've seen describes it as a 30w...or ISO 46 which equals 20 weight....??
Curious where you saw 10w-30?
...and will probably make it into manual by 2013 - 2014...:D
Note the current BX24 WSM makes no mention of UDT or SUDT for replacement fluid, merely the statement I quoted about using a multigrade.
So any new brand specific recommendation may never appear in the manual:)
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #17
I hope you're right as it just confuses people, contrary to what some will say, there is nothing special about Kubota fluids. I have seen more hostility on oil/fluid threads than just about anything else.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #18
I agree and Kubota will tell you to use Kubota air in tires too...This issue has been here longer then you...remember the cowboydoc...As the owner..
Again Kubota is behind them times....alot
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #19
If Kubota fluid SUDT is not specially made for the requirements of the Kubota HST then why do some people switch back to it after using other fluids??? Some accounts refer to the increased whine to not having as much starting power on hills. Please explain why all these accounts are wrong or a figment of the imagination. I do know that when I did the 50 hour service on my L3130 GST and filled with SUDT that the shifting was better and quicker.
David Kb7uns
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #20
David Kb7uns
David, these threads never solve anything. That said, part of the problem is that when folks have switched and then went back to sudt, it is often because they chose a discount, no-name type, generic fluid. That was my experience. No doubt, if I could find a top quality, name brand UTF, I'd likely be more than satisfied with the performance, but that begs the question as to whether I'd save any real money. See the conundrum? Well, mine anyhow.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
ABB Rotterdam Air Compressor (A49461)
ABB Rotterdam Air...
2011 TRAIL-EZE  TE80HT48 HYDRAULIC TRAIL (A50854)
2011 TRAIL-EZE...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
