SUDT vs UDT for BX-24 Official Kubota Recommendation
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #1
Skyco
Elite Member
SC/NC
Changed my hydraulic oil and filter, cleaned the screen etc..at 233 hrs. Second time, first was around 50 hrs.
I checked the Workshop Manual from Kubota just to be sure I remembered it right from almost 3 years ago...
That's when I saw an interesting note that ought to put all the UDT vs SUDT(2) threads to bed.
Quote-
"IMPORTANT
Use only multi-grade transmission oil. Use of other oils may damage the transmission or hydraulic system."
Since the UDT is not a multi-grade that sort of throws a bad light on all the dealers that say UDT is fine, that is all they use yada yada..
Notice they don't say one has to use SUDT but many other oils are NOT multi-grade including UDT.
Asbestos underwear on.:cool:
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #2
I'd swear my manual says either udt or sudt is OK for my 5030. Will be interesting to see what other's say.
It very well may for a 5030- but the title of the thread says BX-24;)
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #4
agreed! That's why I was explicit. Two options exist :
Kubota stands by it's manual.
Kubota says its manual is overly restrictive.
wonder which!
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #5
Since UDT's viscosity is near that of SAE 10 when it is cold and near that of SAE 30 when it is hot, why is it not considered a multi-viscosity oil?
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #6
The WSM for my BX2660 reads the same as Skyco's. It also says that the factory fluid installed by Kubota is SUDT.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #7
You cant always trust a Kubota manual. I have some that have parts break downs in them that he parts are listed wrong and have wrong numbers ect ect ect. I do not believe a whole lot of effort goes into checking these. Many have conflicting maint schedules in thier books also.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #8
Don't really care, I have used Ambra, Case, Kubota SUDT, UDT, Sinclair etc. for years and will continue to do so, if it blows, I'll fix and you can say, "I told you so", but I'm not particularly concerned.
Yes, my dealer who has been in business for over 50 years only stocks UDT most of the time.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #9
I agree. The manuals are outdated and behind the times. Or just dumbed down...
Use either UDT or SUDT and be fine. Heck, several aftermarket fluids are fine too.
   / SUDT vs UDT for BX-24 Official Kubota Recommendation #10
I thought that Kubota came out with a new oil that replaced UDT and SUDT (SUDT II or something like that)...?
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
